Hello community!
I'm interested testing all the cool features to come with the truenas scale project. everything starts with the download and flash of the media. i do have hardware without vga so i have to setup via putty and the console. i tried flashing a nighty with rufus and the dd mode but grub.cfg has got no entries for text mode. so my only option is to flash with the ISO mode and edit the grub.cfg on the usb-drive to get the start menu running
this is the grub.cfg from the nightly:
i tried to build my own grub.cfg with infos from this site here:
my idea is suggesting two entries for gfx mode and txt mode. if permanently added i could use dd for my next tests.
linux /vmlinuz isnt found when starting thats why i linked directly to the images. (no symlink?)
i can make some further grub.cfg tests (not sure if all the options are needed for txt bootup) if helpful for the community.
greetz oliver :)
function load_video { if [ x$feature_all_video_module = xy ]; then insmod all_video else insmod efi_gop insmod efi_uga insmod ieee1275_fb insmod vbe insmod vga insmod video_bochs insmod video_cirrus fi } if loadfont $prefix/fonts/unicode.pf2 ; then set gfxmode=auto load_video insmod gfxterm set locale_dir=$prefix/locale set lang=en_US set gfxpayload=keep fi terminal_output gfxterm serial --unit=0 --speed=9600 --word=8 --parity=no --stop=1 set menu_color_normal=cyan/blue set menu_color_highlight=white/blue terminal_output gfxterm if [ "${recordfail}" = 1 ] ; then set timeout=30 else if [ x$feature_timeout_style = xy ] ; then # set timeout_style=hidden set timeout=3 # Fallback hidden-timeout code in case the timeout_style feature is # unavailable. elif sleep --interruptible 0 ; then set timeout=3 fi fi insmod play play 960 440 1 0 4 440 1 menuentry --hotkey=i 'Start TrueNAS SCALE Installation' { load_video set background_color=black linux /vmlinuz vga=788 --- quiet nomodeset boot=live toram=filesystem.squashfs console=ttyS0,9600 console=tty0 initrd /initrd.img }
function load_video { insmod efi_gop insmod efi_uga insmod video_bochs insmod video_cirrus insmod ieee1275_fb insmod vbe insmod vga insmod all_video } function load_gfx { insmod gfxmenu insmod gfxterm insmod gfxterm_menu insmod gfxterm_background gfxmode=auto gfxpayload=keep menu_color_normal=cyan/blue menu_color_highlight=white/blue background_color=black color_normal=yellow/black terminal_output gfxterm } set timeout=10 set default=1 set gfxpayload=text set console=ttyS0,115200 set console=tty0 serial --speed=115200 --unit=0 --word=8 --parity=no --stop=1 terminal_input serial console terminal_output serial console #menu entries menuentry 'Start TrueNAS SCALE Installation video' --hotkey=i { load_video load_gfx linux /vmlinuz vga=788 --- quiet nomodeset boot=live toram=filesystem.squashfs console=ttyS0,9600 console=tty0 initrd /initrd.img } menuentry 'Start TrueNAS SCALE Installation text' --hotkey=i { echo 'Loading vmlinuz ...' linux /boot/vmlinuz-5.9.0-1-amd64 gfxpayload=text quiet nomodeset boot=live toram=filesystem.squashfs console=ttyS0,115200 console=tty0 echo 'Loading initial ramdisk ....' initrd /boot/initrd.img-5.9.0-1-amd64 }
greetz oliver :)
