edit home assistant configuration.yaml
tziegler
Good evening
I installed home assistant on Truenas Scale and enabled "Custom Host Path for Home Assistant Configuration Storage Volume ".
I can see the configuration.yaml file in my SMB share but can't read or edit the file.
is there a way to change the permissions of the configuration.yaml file?
If you need more informations let me know.
(I'm a beginner)
dgrigo
use winscp with root login or command line
hope answers your question.
Its not recommended method and of course unsupported .
/best
tziegler
thanks for your reply
but I was able to get it working. I deleted the app and the share.
-I created a new dataset
-installed the app with "Custom Host Path for Home Assistant Configuration Storage Volume " enabled (choosing the newly added dataset)
-changed the Permissions (user: the user who needs access group: left group user as it was) check the box: „Apply permissions recursively“
and „Apply permissions to child datasets“ I didn‘t use the ACL and I‘m not sure if it makes a difference
-now I added it to my smb share and I was able to edit the files
