E-mailing test message does not work
Gasha
I just put together a NAS box two days ago. I used all latest software from FreeNAS.
Here is my configuration:
Global Configuration
IPv4 Default Gateway 192.168.1.1 (my router)
Nameserver 1 8.8.8.8
Nameserver 2 209.18.47.61 (roadrunner)
Nameserver 3 209.18.47.62 (roadrunner)
System Settings Email
From email myname@gmail.com
outgoing mail server smtp.gmail.com
Port to connect to 465 (I tried 587, it did not make any difference)
Use SMTP Authentication Checked
username myname@gmail.com
password my gmail password
Whew I click Send button I get:
Your test email could not be sent: [Errno 8] hostname nor servname provided, or not known
I can "ping 8.8.8.8" or "ping google.com" from the shell.
Any ideas what is wrong with my setup are very much appreciated.
Gasha
Try searching for "smtp gmail". Please use the search feature and at other threads to help answer your question next time. :)
Gasha
I did look other threads and nothing helped me. There is no clear answer.
Gasha
One more thing, I am not familiar with Linix so I can not do the shell thing. All I want is to succesfully send test email and stick to GUI.
If there is a thread that gives clear reason why it does not work and way arround it, please let me know.
Gasha
I fixed it !!!!!!
I replaced "smtp.gmail.com" with IP address "74.125.133.108" and it WORKED! I have sent and received a test email.
Now, why when I ping "smtp.gmail.com" from shell it works, e.g. the name gets resolved, but the name does not work in
smtp setup? Is this a bug ? Can a FreeNAS guru explain this?
Gasha
Thnak you for quick reply.
I did read that thread, my settings are exactly the same and I still coud not send test email.
I tried both port numbers it did not make difference. The question is why ping within the shell
resolves url correctly and emil setup does not? Do I really have DNS problem or there is a bug in FreeNAS?
I attched a screen capture of the ping.
Gasha
If you change back to smtp.gmail.com does the email stop working?
Gasha
Damn! It does work now even with "smtp.gmail.com". Anyway, thank you for you help, I appreciate it.
Gasha
I was willing to bet money that changing it to the IP didn't fix it. ;)
