I have been using ZFS for over a year and a half now, primarily on Ubuntu, but I cannot for the life of me figure out how to create (using the gui in FreeNas 9.1.1) an array using several different hdd sizes.
Background, I've got about 2.5 TB of data I backed up to a 3TB drive and verified in order to re-create my array with the 4k sectors. I tried using FreeNas to do so using the remaining drives.
My drives:
1 x 3TB full of data
4 x 3TB
1 x 1TB
1 x 500GB
My plan is to create a Raidz1 using the six drives there, then load all data from the 3TB drive onto it, then swap the 500G for the 3TB to increase my array size to around ~5TB (later to be increased to 15TB when I have my next $150 to spend on the last 3TB drive).
Problem is I open the ZFS volume manager, type in a pretty name, and I've tried a vast assortments thereafter to create a 6x500G RaidZ1 array but it only comes up with being able to do a 4x3TB with a 1TB spare and a 500G spare which I can also choose to stripe. Oh and it won't let me do a Z1, it insists on a Z2 to be "optimal". Anything I manually type in messes it up so I can't seem to do that either. Any help would be appreciated, I'd like to see if creating an array 100% on FreeNas would result in faster speedtests than one transferred from a Ubuntu creation. Lastly I've tried creating a volume of 1x500GB and "Extending" it using the "Volume to extend" drop-down, also to no avail. I am unfamiliar to FreeNAS or the underlying FreeBSD kernel and its accompanying terminology or command prompt syntax so I would like to avoid this if at all possible.
The reason I believe this may be a bug is that I presume there was an effort to make this "dummy-proof", but one would think there would at least be an "advanced" button over-ride or something similar? I believe thustly that it would prove to be pretty dumb without said button, thereby becoming 'dumb-proof'.
I've searched quite a bit for an answer for this.
Lastly, and slightly off-topic, (and I didn't search for this), is there a way to force FreeNAS to use more of a /dev/disk/by-id type labeling system rather than the normal ada0, ada1 type? I frequently swap motherboards and other hardware so it would be nice to ensure if I swap it to something it won't go and accidentally wipe out any of my existing drives on said new system.
Thank you all very much for any help and responses.
My drives:
4 x 3TB
1 x 1TB
1 x 500GB
