Glorious1
 - Nov 23, 2014
I have a subdomain set up duckdns.org to update with my IP every 6 hours.  It was working fine for a long time and now it isn't updating.
There is a cron task. Every 6 hours, 'nobody' does
/usr/local/bin/curl https://duckdns.org/update/<subdomain>/<token>
When you run that manually from your Freenas account, it normally would return 'OK' if it worked, and 'KO' if it didn't.
However, now it returns:
<html>
<head><title>301 Moved Permanently</title></head>
<body bgcolor="white">
<center><h1>301 Moved Permanently</h1></center>
<hr><center>nginx/1.4.6 (Ubuntu)</center>
</body>
</html>
I can still log into duckdns.org and update the IP manually. I have no way to contact them. Do you think the problem is at their end or something with my Freenas?
<html>
</body>
</html>
