Sorry if this is in the wrong section, but I spent a little while trying to figure this out myself and wanted to post my solution as I can't really find any good explanations on how to set this up.
First off, you want to go to DuckDNS, log in, and create your subdomain. For this example, I used "mickmodnas".
On the top of the page, under your e-mail there is a line that says "token" before a long string that looks something like this: 47888478-6969-4321-1234-4048cc51337 (This is not a real token BTW), you want to copy this and keep it handy.
Now let's get started with setting it all up.
- Open the web UI dashboard on your computer.
- On the left side of the screen, click "Tasks" then click "Cron Jobs" from the dropdown.
- Click the "Add" button.
a. In the "Description" field, add what you want to help you identify it being your DuckDNS cron job. I use "DuckDNS Update" on my NAS.
b. In the "Command" field, add the script I put below.
c. In "Run As User", put in "nobody".
d. Select how often you want it to update the DNS, I have only tested this with 1 minute past an hour. I like updating the DNS every 3 hours.
My update schedule is:
Minutes: 1
Hours: */3 (Every 3 hours)
Days: * (Every day)
Leave the month/weekday fields empty to update every day the whole year.
e. Click "Done" in the Schedule window, then click the "Submit" button. - You can now test the script by clicking on the arrow next to the cron job you just made, and clicking "Run Now".
- You are now finished!
Script: /usr/local/bin/curl http://www.duckdns.org/update/YOURSUBDOMAIN/YOURTOKEN Example: /usr/local/bin/curl http://www.duckdns.org/update/mickmodnas/47888478-6969-4321-1234-4048cc51337
