Supermicro X10 + E5-1620 v4
RAM: 128GB (6 module) 2400 ECC
HBA: 2 x LSI 9211
NIC: Chelsio T420 dual 10G (foreseeable max: 2)
Fans: 9 120mm AP121 (foreseeable max: 12)
PSU: EVGA Supernova G2 750W (underpowered, to be upgraded)
Storage:
16 x 7200 enterprise, mixed SAS/SATA (foreseeable max: 22-24)
Usage: 3 way mirrors (3x4TB+3x6TB+3x6TB+3x8TB) + test pool/spares, main pool capacity 22TB @ 55-60% usage, dedup saving 3.9x
ZIL: Intel P3700 NVMe
L2ARC: Samsung 250gb NVMe
Boot: 2 x Intel 320 SSD mirror
Power draw/temp: staggered start enabled, vertical fanned, disk temps 28-35C
HBA: 2 x LSI 9211
Storage:
I'm unhappy about the PSU in my current build and plan to upgrade that area. It's anEVGA Supernova G2 - single rail, accolades for build quality, stability and quality, like many of EVGA/Superflower's current lineup, but only 750W and I'm running way more disks than I originally planned, to the point that I'm not sure how it hasn't fallen over yet. I don't feel I want to chance my luck further so some kind of upgrade is going to happen.
I've enabled staggered startup on all but boot drives, but the HDDs are mostly rated as drawing up to 1.5A on 5v and 3.08A on 12v as a worst (peak/transient) case. There are currently 16 HDDs and potentially I can see a future need for up to 22-24 disks, although perhaps in 2 pools and not all active at the same time. They are all directly powered, there's no separate backplane. There are also significant power-drawing components powered from the baseboard - 10G cards, high performance SSDs, ECC, CPU, and fans.
Being fair, 90% of the time the NAS isn't doing heavy work, but even ordinary work can do a lot - major file copying/moving, scrubs, resilvers, multitasking, and writing data from clients. I've had Samba working at 1GByte/sec writes, and the pool has potentially got up to 18 HDDs in it + ZIL + L2ARC now (and could have more than 20 in future), so if they all get writing, there's a fair load.
Working out my current needs based on absolute peak current draw, I'm beyond the 1200W level and looking at a 1600W - 2000W PSU when one allows for overhead and reduced performance over its lifetime (1300-1400W on 12v and potentially up to 36A transient draw on 5v if every one of 24 disks needed its peak current simultaneously, although that's unlikely). But as it's already been handling 16 HDDs on a 750W PSU for months, asserting that 1200W isn't enough seems excessive. I'm not sure what to think.
I'm also especially wondering if it's safe to use two 750W as dual PSUs, and split the HDDs between them, rather than a monolithic 1600W. I can't get the kind of dual-PSU case one might get if doing this in a business, so it's either big or dual. These are the pros and cons I can think of:
- Big PSU (1200W or 1600W, platinum): "Usual solution" hence known to work. But expensive for 1200W and very expensive indeed for 1600W (£320-£400 for EVGA and £380-480 for Superflower), here in the UK. 2000W is plain unaffordable at those rates :) There's a second problem which is that these large PSUs are mainly designed for driving multiple graphics cards, so the 5v rail only goes up to 24-30A - by contrast my load is disproportionately heavy on 5v since I'll have up to 20-24 HDDs with specs giving up to 1.5A @ 5v each for peak draw, plus anything else needing it. So even a very large monolithic PSU might struggle with the 5v draw in some extreme cases, even if perhaps unlikely. Also the larger EVGA models only have 5 cable ports for drives so I'd have to load every port fully which isn't ideal for cable heating and maximum current per cable limits.
- Dual PSU (750W + 750/850W): Ideal in every way except for my big unresolved concern - I'm apprehensive whether it's as safe as a monolithic PSU, insofar as I've only ever used a single PSU. Then again the electrics seem sensible - make the power connection common to both (for on/off function), crosswire the ground planes (common ground), and use one for baseboard + 1/3 of the disks and the other one for the other 2/3 of the disks. I'd buy another of the same brand/line as I already have. If buying a dual PSU cable also need to check the pins are done right, but there are resources for this online, and with bitcoin mining rigs this isn't as freakish/uncommon as it once was. It also gets me 8-10 cable ports rather than 5 to split my HDDs across, it immediately gets me up to 48A on 5v as well as sufficient 12v, and perhaps lower fan noise (heat split between 2 units and 2 less-loaded fans). Since the PSUs only have 0v in common and one only powers the baseboard+ some HDDs while the other only powers the remaining HDDs, there isn't apparently scope for one to take all the load leaving the other idle, or for current loops, but I don't have the knowledge to exclude the risk of other interactions such as ground plane, or supply-side earthing, or the data cables coming from a board supplied by PSU1 and connected to a HDD powered by 5v/12v (from the same 0v plane) from PSU2. That sort of thing.
Regarding dual PSUs - I'm confident of my ability to check the wiring and wire it up, but what are the running implications of two high quality PSUs paralleled this way, both providing 5v and 12v to different components on the same system? There shouldn't be current loops but electrically I'm not sure what the implications would be. Could there be much/any risk to my hardware and drives? Or is it pretty much totally safe given some technical knowhow and solid high quality cross-connections? Is it basically the same as any other redundant PSU system and really 100% straightforward/normal?
Otherwise if it's monolithic, what wattage is likely to be sufficient?
