VladTepes
 - May 18, 2016
Hi I posted this in the PSU thread itself but not sure if anyone will notice it there, so posting as its own thread, as I need a response.
I have read the instructional portions of the PSU sizing thread, which are very useful :)
I am building a dual system off of one PSU using a Phanteks Power Splitter.
The systems are as follows:
ROMULUS
MOBO: Asus Z170I Pro Gaming LGA 1151 Mini ITX
RAM: Corsair CMU32GX4M2C3200C16R 32GB (2x16GB) DDR4 3200MHz Vengeance Black with Red LED
CPU: Intel Core i7 6700K Quad Core LGA 1151 4GHz Unlocked CPU Processor
GPU: NVidia GeForce GTX970 FTW
SSD1: Samsung 950 Pro Series 512GB M.2 SSD (boot/system/office)
SSD2: Samsung 840Evo 500Gb (game library)
SSDD3: Might or might not use it Samsung 840Evo 256Gb
HDD1: WD Blue 6Tb
Optical: LG 16x BluRay R/W & DVD R/W (LG-BH16NS40)
Fans ???
REMUS (The NAS system)
Mobo: Supermicro X11SSL-F
CPU: Intel i3-6100
RAM: 32Gb Samsung ECC unbuffered RAM
Boot / System drive: Kingston V400 120Gb SSD
NAS drives: 4 x WD Red NAS 3TB (but cater for 5).
So this is my calculation. Where the internet indicated a number of figures for power consumption the higher figure was used. This has resulted in a very conservative outcome - probably far exceeding the actual requirement.
OK so with the specs I've posted in mind we have:
MOBO 2 x 80W = 160W (I'm sure the real figure would be much lower)
HDD's 6 x 35W = 210W (Normal load is lower, but this allows for possible simultaneous spin up of all drives).
SSDs x 4 @ 3.5W = 14W
CPU1: i7 6700K 91W TPU
CPU2: i3 6100 51W TPU
RAM 4 x DDR4 16gb @ 6W each max = 24W
GPU: 300W max (some sources 250W)
Blue Ray Drive: 30W (max while writing)
Fans - say 4 or 5 case plus 2 CPU fans - so I've said equivalent of 5 140mm fans @ 30W each (again likely to be a massive over-estimate) = 150W
There will also be an Arduino and a few LED strips running off it, they don't take up much at all.
The total PEAK consumption based on my calcs is 975W.
In reality it will be much lower most of the time, but being this is includes a NAS system I need to ensure no potential issues.
This thread says to multiply the figure by 1.25 to get a target PSU size, which works out around the 1200W mark. )
In short, the 750W supply will probably be fine. But probably doesn't really satisfy me I really want to be sure any POTENTIAL PEAK use of the two system simultaneously does not exceed the comfort / efficiency level of the power supply. Admittedly this scenario - peak use of both systems simultaneously is extremely unlikely.
So I suppose I'm on the lookout for a fully modular 1200W PSU Gold 80+ rated. Or am I?
Interestingly if we look at various power calculators on the internet they calculate the draw / recommendations as follows:
Powersupplycalculator 584W Draw, Recommend 804W
MSI calculator Recommend minimum 494W (I assume this is their estimated actual draw figure, but can't be sure)
Coolermaster calculator: 616WDraw, Recommend 716W
(For others reference, powersupplycalculator link was dated - no 6th gen CPU's etc.)
(The easiest to use was the Coolermaster one.)
Whether any are correct - well, that's a tough one.
For a typical gaming or home use system I'd use the Coolermaster calculator, with a very high degree of confidence.
For a system including NAS (in this case FreeNAS) it gets a bit more complicated and doing it manually highlights some real-world differences.
Hmmm.
Recommendations from other forums suggest that "750W would easily do the job", and that "850W would be plenty".
I'd appreciate advice / thoughts on this please.
If 1000W is more than enough, then I have a line on a EVGA SuperNOVA P2 1000W PSU (1+ Year old, 80% warranty left, 9.7 score from JohnGuru) for a good price but need to know ASAP.
Thank you ! :)
ROMULUS
HDD1: WD Blue 6Tb
Fans ???
CPU: Intel i3-6100
Hmmm.
Thank you ! :)
