drive shows up in Disk View web ui but not in glabel status
ddep
Here is my zpool status, glabel status and webui disk view
[root@nas] /mnt/data1# zpool status
pool: data1
state: ONLINE
scan: none requested
NAME STATE READ WRITE CKSUM
data1 ONLINE 0 0 0
raidz1-0 ONLINE 0 0 0
gptid/27a76b0c-9d80-11e5-afd3-d050997eea4b ONLINE 0 0 0
gptid/28840d84-9d80-11e5-afd3-d050997eea4b ONLINE 0 0 0
gptid/296c93ad-9d80-11e5-afd3-d050997eea4b ONLINE 0 0 0
gptid/2a591369-9d80-11e5-afd3-d050997eea4b ONLINE 0 0 0
gptid/2b49a7b2-9d80-11e5-afd3-d050997eea4b ONLINE 0 0 0
errors: No known data errors
pool: download
state: ONLINE
download ONLINE 0 0 0
gptid/03c5f228-9b1c-11e5-8903-d050997eea4b ONLINE 0 0 0
pool: freenas-boot
state: ONLINE
freenas-boot ONLINE 0 0 0
da0p2 ONLINE 0 0 0
[root@nas] /mnt/data1# glabel status
Name Status Components
gptid/b0105b69-9a1d-11e5-b2b3-d050997eea4b N/A da0p1
gptid/27a76b0c-9d80-11e5-afd3-d050997eea4b N/A ada0p2
gptid/28840d84-9d80-11e5-afd3-d050997eea4b N/A ada1p2
gptid/296c93ad-9d80-11e5-afd3-d050997eea4b N/A ada3p2
gptid/2a591369-9d80-11e5-afd3-d050997eea4b N/A ada4p2
gptid/03c5f228-9b1c-11e5-8903-d050997eea4b N/A ada5p2
gptid/2b49a7b2-9d80-11e5-afd3-d050997eea4b N/A ada6p2
gpsguy
Active Member
ddep
My point is that I can't reference that new drive. I can't call gpart against it at all. and I don't see it under /dev/
Bidule0hm
Server Electronics Sorcerer
Do you know the serial number of this drive?
Bidule0hm
Ok, use this script to see if the drive shows up or not, and if yes then the other infos linked to this drive: http://pastebin.com/GXUTK7AZ ;)
ddep
here is the output of the script:
| Device | GPTID | Serial |
| ada0 | gptid/27a76b0c-9d80-11e5-afd3-d050997eea4b | WD-WCC4E7EF2LR2 |
| ada1 | gptid/28840d84-9d80-11e5-afd3-d050997eea4b | WD-WCC4E5KZ197D |
glabel: No such geom: ada2p2.
| ada2 | | 5QG31MLP |
| ada3 | gptid/296c93ad-9d80-11e5-afd3-d050997eea4b | WD-WCC4E5KZ1AV3 |
| ada4 | gptid/2a591369-9d80-11e5-afd3-d050997eea4b | WD-WCC4E2EX36AE |
| ada5 | gptid/03c5f228-9b1c-11e5-8903-d050997eea4b | 5QG0R0Y8 |
| ada6 | gptid/2b49a7b2-9d80-11e5-afd3-d050997eea4b | WD-WCC4E6RX8S7R |
solarisguy
I would say you have a dead disk with serial number 5QG31MLP.
Just in case, connect it to another system (Linux, Unix, Windows) and try to run S.M.A.R.T on it there.
ddep
I think I know what I did. I removed that drive and test it on another machine and the drive is fine.
I tried to setup the mirror with another drive and I noticed that after I did "gpart destroy ada2" that's when the drive disappeared from the glabel status, but I can still call "gpart create ada2" which added the drive back to the glabel status list. Previously I just assumed i can't call gpart create when I can't see the drive.
Thanks for your help. The mirror is now successfully setup.
gpsguy
Active Member
It would have been helpful to know that you didn't even try "gpart create ada2", when I asked whether you'd done it. I got the impression you had an error of some sort, when you said "I can't call gpart against it at all."
At least it's working now.
ddep
I think I call "gpart create /dev/ada2p1" previously but that failed, that's when I did glabel status and noticed device wasn't listed, which led me to believe the issues are related.
When I tried yesterday I did "gpart create ada2".
gpsguy
Active Member
So, you didn't use the syntax used in paleoN's referenced message and your's didn't work. Did you add the swap partition?
    gpart create -s gpt ada0
    gpart add -i 1 -t freebsd-swap -s 2G ada0
    gpart add -i 2 -t freebsd-zfs ada0
