Micheal Shallop
- Oct 30, 2015
Hey all,
I'm still figuring out stuffs here... basically, for about the last two months, I've been getting warnings about a imminent drive failure. The day finally arrived where the drive failed completely following an OS update, and I replaced the physical drive with a identical (make/model) replacement unit.
Within 24-hours, this drive was flagged as bad, removed from the pool, and the state downrev'd to degraded.
These are 3TB Seagate drives. The failing drive physically is located at the bottom of a 4-drive stack in the case.
zpool and smartctl output follows.
I am wondering if I have larger issues - such as bad DMA controller, cable, poor ventilation, that's causing the same drive to fail... or was this just dumb luck?
Also, I updated (the OS) and rebooted and the drive is still marked as offline.
Is there a way to "replace" it without removing it a forcing a resilver? Or was there something in the below output that says: this drive is toast.
Thanks!
--mike
Thanks!
--mike
# zpool status -v
pool: cmv1
state: DEGRADED
status: One or more devices could not be opened. Sufficient replicas exist for
the pool to continue functioning in a degraded state.
action: Attach the missing device and online it using 'zpool online'.
see: http://illumos.org/msg/ZFS-8000-2Q
scan: scrub repaired 0 in 5h52m with 0 errors on Mon Nov 2 13:31:21 2015
NAME STATE READ WRITE CKSUM
cmv1 DEGRADED 0 0 0
raidz2-0 DEGRADED 0 0 0
gptid/e8edd6b3-c76f-11e3-9218-e03f49abb2ba ONLINE 0 0 0
13440795819143157447 UNAVAIL 0 0 0 was /dev/gptid/e3cb7441-7f4f-11e5-b243-e03f49abb2ba
gptid/e9f806f3-c76f-11e3-9218-e03f49abb2ba ONLINE 0 0 0
gptid/ea7c6e25-c76f-11e3-9218-e03f49abb2ba ONLINE 0 0 0
errors: No known data errors
pool: freenas-boot
state: ONLINE
scan: scrub repaired 0 in 0h0m with 0 errors on Thu Oct 29 03:45:28 2015
freenas-boot ONLINE 0 0 0
ada0p2 ONLINE 0 0 0
errors: No known data errorsCode:
# smartctl -x /dev/ada2
smartctl 6.3 2014-07-26 r3976 [FreeBSD 9.3-RELEASE-p29 amd64] (local build)
Model Family: Seagate Barracuda 7200.14 (AF)
Device Model: ST3000DM001-1CH166
Serial Number: Z1F49BDW
LU WWN Device Id: 5 000c50 065710cd3
Firmware Version: CC29
User Capacity: 3,000,592,982,016 bytes [3.00 TB]
Rotation Rate: 7200 rpm
Form Factor: 3.5 inches
ATA Version is: ACS-2, ACS-3 T13/2161-D revision 3b
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Tue Nov 3 07:21:42 2015 PST
SMART support is: Enabled
AAM feature is: Unavailable
APM feature is: Disabled
Rd look-ahead is: Enabled
Write cache is: Enabled
ATA Security is: Disabled, frozen [SEC2]
Wt Cache Reorder: Unavailable
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
been run.
data collection: ( 575) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 334) minutes.
Conveyance self-test routine
SCT capabilities: (0x3085) SCT Status supported.
ID# ATTRIBUTE_NAME FLAGS VALUE WORST THRESH FAIL RAW_VALUE
1 Raw_Read_Error_Rate POSR-- 114 099 006 - 60364008
3 Spin_Up_Time PO---- 095 095 000 - 0
4 Start_Stop_Count -O--CK 100 100 020 - 31
5 Reallocated_Sector_Ct PO--CK 100 100 010 - 0
7 Seek_Error_Rate POSR-- 078 060 030 - 60937646
9 Power_On_Hours -O--CK 085 085 000 - 13372
10 Spin_Retry_Count PO--C- 100 100 097 - 0
12 Power_Cycle_Count -O--CK 100 100 020 - 31
183 Runtime_Bad_Block -O--CK 100 100 000 - 0
184 End-to-End_Error -O--CK 100 100 099 - 0
187 Reported_Uncorrect -O--CK 100 100 000 - 0
188 Command_Timeout -O--CK 100 099 000 - 0 0 1
189 High_Fly_Writes -O-RCK 099 099 000 - 1
190 Airflow_Temperature_Cel -O---K 062 051 045 - 38 (Min/Max 29/44)
191 G-Sense_Error_Rate -O--CK 100 100 000 - 0
192 Power-Off_Retract_Count -O--CK 100 100 000 - 25
193 Load_Cycle_Count -O--CK 100 100 000 - 57
194 Temperature_Celsius -O---K 038 049 000 - 38 (0 18 0 0 0)
197 Current_Pending_Sector -O--C- 100 100 000 - 0
198 Offline_Uncorrectable ----C- 100 100 000 - 0
199 UDMA_CRC_Error_Count -OSRCK 200 200 000 - 0
240 Head_Flying_Hours ------ 100 253 000 - 13372h+28m+23.086s
241 Total_LBAs_Written ------ 100 253 000 - 17839686132
242 Total_LBAs_Read ------ 100 253 000 - 60259271841
||||||_ K auto-keep
|||||__ C event count
||||___ R error rate
|||____ S speed/performance
||_____ O updated online
|______ P prefailure warning
General Purpose Log Directory Version 1
SMART Log Directory Version 1 [multi-sector log support]
Address Access R/W Size Description
0x00 GPL,SL R/O 1 Log Directory
0x01 SL R/O 1 Summary SMART error log
0x02 SL R/O 5 Comprehensive SMART error log
0x03 GPL R/O 5 Ext. Comprehensive SMART error log
0x06 SL R/O 1 SMART self-test log
0x07 GPL R/O 1 Extended self-test log
0x09 SL R/W 1 Selective self-test log
0x10 GPL R/O 1 NCQ Command Error log
0x11 GPL R/O 1 SATA Phy Event Counters
0x21 GPL R/O 1 Write stream error log
0x22 GPL R/O 1 Read stream error log
0x80-0x9f GPL,SL R/W 16 Host vendor specific log
0xa1 GPL,SL VS 20 Device vendor specific log
0xa2 GPL VS 4496 Device vendor specific log
0xa8 GPL,SL VS 129 Device vendor specific log
0xa9 GPL,SL VS 1 Device vendor specific log
0xab GPL VS 1 Device vendor specific log
0xb0 GPL VS 5176 Device vendor specific log
0xbe-0xbf GPL VS 65535 Device vendor specific log
0xc0 GPL,SL VS 1 Device vendor specific log
0xc1 GPL,SL VS 10 Device vendor specific log
0xc4 GPL,SL VS 5 Device vendor specific log
0xe0 GPL,SL R/W 1 SCT Command/Status
0xe1 GPL,SL R/W 1 SCT Data Transfer
SMART Extended Comprehensive Error Log Version: 1 (5 sectors)
No Errors Logged
SMART Extended Self-test Log Version: 1 (1 sectors)
# 1 Conveyance offline Completed without error 00% 13368 -
# 2 Short offline Completed without error 00% 13367 -
# 3 Conveyance offline Completed without error 00% 13344 -
# 4 Short offline Completed without error 00% 13343 -
# 5 Conveyance offline Completed without error 00% 13320 -
# 6 Short offline Completed without error 00% 13319 -
# 7 Conveyance offline Completed without error 00% 13295 -
# 8 Short offline Completed without error 00% 13294 -
# 9 Conveyance offline Completed without error 00% 13274 -
#10 Short offline Completed without error 00% 13273 -
#11 Conveyance offline Completed without error 00% 13251 -
#12 Short offline Completed without error 00% 13250 -
#13 Conveyance offline Completed without error 00% 13227 -
#14 Short offline Completed without error 00% 13226 -
#15 Conveyance offline Completed without error 00% 13203 -
#16 Short offline Completed without error 00% 13202 -
#17 Conveyance offline Completed without error 00% 13179 -
#18 Short offline Completed without error 00% 13178 -
#19 Conveyance offline Completed without error 00% 13154 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
SCT Status Version: 3
SCT Version (vendor specific): 522 (0x020a)
SCT Support Level: 1
Device State: Active (0)
Current Temperature: 38 Celsius
Power Cycle Min/Max Temperature: 29/44 Celsius
Lifetime Min/Max Temperature: 18/49 Celsius
Under/Over Temperature Limit Count: 0/0
SCT Data Table command not supported
SCT Error Recovery Control command not supported
Device Statistics (GP Log 0x04) not supported
SATA Phy Event Counters (GP Log 0x11)
ID Size Value Description
0x000a 2 7 Device-to-host register FISes sent due to a COMRESET
0x0001 2 0 Command failed due to ICRC error
0x0003 2 0 R_ERR response for device-to-host data FIS
0x0004 2 0 R_ERR response for host-to-device data FIS
0x0006 2 0 R_ERR response for device-to-host non-data FIS
0x0007 2 0 R_ERR response for host-to-device non-data FIS
