Drive Name changed
clifford64
I have a 12 disk x 6 mirror pool that I have been slowly replacing drives in. I recently ran into an issue where my drive names seem to have changed.
Previously, I had it ordered so the name of the drive matched up with the slot the drive was in. Being that these are mirrors, I would like to keep them together for organization purposes. For example, da0=drive 1, da1=drive 2, da2=drive 3 and so on.
Now, the physical disk order hasn't changed, but the drive names have. da0-da2 are normal, but da11= Drive 3, da3= drive 5, da4= drive 6. Like the daX has shifted for some reason.
Now I know this has no impact on my pool because truenas uses the GPTID to map them to the vDevs, but it would be nice to get the correct order back. I have already tried a reboot, but that didn't do anything. I tried popping out the drive and then putting it back in, but that didn't seem to do anything either. Any ideas?
Potentially export/offline the pool and then pop the drives in one at a time so the order is recognized? Or just leave it alone. I have been using the daX number to match up the physical drive location in my documentation. Should I be using something else in my documentation like the GPTID instead and drop daX number?
zpool status
  pool: iSCSI-Pool
 state: ONLINE
  scan: resilvered 6.37M in 00:00:02 with 0 errors on Thu May  5 12:28:25 2022
        iSCSI-Pool                                      ONLINE       0     0     0
          mirror-0                                      ONLINE       0     0     0
            gptid/5ccaae80-c3ab-11ea-99a0-001e67ae35eb  ONLINE       0     0     0
            gptid/b0b6fe1a-9940-11eb-a106-001e67ae35eb  ONLINE       0     0     0
          mirror-1                                      ONLINE       0     0     0
            gptid/5cd67028-c3ab-11ea-99a0-001e67ae35eb  ONLINE       0     0     0
            gptid/a46c29de-9d5f-11ec-b18d-001e67ae35eb  ONLINE       0     0     0
          mirror-2                                      ONLINE       0     0     0
            gptid/5a6c40ff-c3ab-11ea-99a0-001e67ae35eb  ONLINE       0     0     0
            gptid/37818987-b84f-11eb-b40f-001e67ae35eb  ONLINE       0     0     0
          mirror-3                                      ONLINE       0     0     0
            gptid/5b660348-c3ab-11ea-99a0-001e67ae35eb  ONLINE       0     0     0
            gptid/e14b791a-adab-11eb-b40f-001e67ae35eb  ONLINE       0     0     0
          mirror-4                                      ONLINE       0     0     0
            gptid/c2f15a23-7022-11ec-bffa-001e67ae35eb  ONLINE       0     0     0
            gptid/658b8681-c3ab-11ea-99a0-001e67ae35eb  ONLINE       0     0     0
          mirror-5                                      ONLINE       0     0     0
            gptid/648a198d-c3ab-11ea-99a0-001e67ae35eb  ONLINE       0     0     0
            gptid/8e9e03ce-a45e-11eb-b40f-001e67ae35eb  ONLINE       0     0     0
        cache
          gptid/95deded5-89b4-11eb-a106-001e67ae35eb    ONLINE       0     0     0
errors: No known data errors
glabel status
                                      Name  Status  Components
gptid/245116d1-bef3-11e9-9870-001e67ae35eb     N/A  ada0p1
gptid/95deded5-89b4-11eb-a106-001e67ae35eb     N/A  ada1p1
gptid/5ccaae80-c3ab-11ea-99a0-001e67ae35eb     N/A  da0p2
gptid/b0b6fe1a-9940-11eb-a106-001e67ae35eb     N/A  da1p2
gptid/5cd67028-c3ab-11ea-99a0-001e67ae35eb     N/A  da2p2
gptid/37818987-b84f-11eb-b40f-001e67ae35eb     N/A  da3p2
gptid/5a6c40ff-c3ab-11ea-99a0-001e67ae35eb     N/A  da4p2
gptid/e14b791a-adab-11eb-b40f-001e67ae35eb     N/A  da5p2
gptid/5b660348-c3ab-11ea-99a0-001e67ae35eb     N/A  da6p2
gptid/c2f15a23-7022-11ec-bffa-001e67ae35eb     N/A  da7p2
gptid/658b8681-c3ab-11ea-99a0-001e67ae35eb     N/A  da8p2
gptid/648a198d-c3ab-11ea-99a0-001e67ae35eb     N/A  da9p2
gptid/a46c29de-9d5f-11ec-b18d-001e67ae35eb     N/A  da11p2
gptid/8e9e03ce-a45e-11eb-b40f-001e67ae35eb     N/A  da10p2
gptid/8e800362-a45e-11eb-b40f-001e67ae35eb     N/A  da10p1
gptid/5716c193-c3ab-11ea-99a0-001e67ae35eb     N/A  da0p1
NugentS
I use serial number. the /dev/dax is arbitary and can change on a reboot. The GPTID is too big to be useable
I have a visio diagram that I have model, serial number and pool written on (hmm, must update that as I have removed some disks - as with all documentation keeping it up to date is the problem).
clifford64
So probably not worth trying to change the daX number to match?
NugentS
If you move drives around or remove them and re-insert in a different order, the drive identifier (daX) can change.
If you wipe and re-partition a disk, the gptid will change.
So with both of those items being variable for a physical disk, stick with serial number.
