SOLVED Matching GPTID and Disk Serial Number
Raggou
I have replaced disks in Truenas before but for some reason my brain isnt working properly and Im having a heck of a time identifying which disk has failed here.
root@truenas[~]# zpool status -v
  pool: BigPool
 state: DEGRADED
status: One or more devices has been removed by the administrator.
        Sufficient replicas exist for the pool to continue functioning in a degraded state.
action: Online the device using zpool online' or replace the device with 'zpool replace'.
  scan: scrub in progress since Mon Sep 5 13:29:55 2022
        1.72T scanned at 1.21G/s, 1.26T issued at 907M/s, 35.0T total 0B repaired, 3.60% done, 10:49:40 to go
    BigPool                                         DEGRADED     0     0     0
      raidz2-0                                      DEGRADED     0     0     0
        gptid/0ca962ee-da71-11ea-93a2-ac1f6b251ca2  ONLINE       0     0     0
        gptid/6cfe1c23-646e-11e9-8739-ac1f6b251ca2  ONLINE       0     0     0
        gptid/6d9df05f-646e-11e9-8739-ac1f6b251ca2  ONLINE       0     0     0
        gptid/3ade1e2d-3143-11ec-9a85-ac1f6b251ca2  ONLINE       0     0     0
        gptid/9b328bb5-ceb1-11ea-b827-ac1f6b251ca2  ONLINE       0     0     0
        gptid/4d055245-ce00-11ea-9915-ac1f6b251ca2  ONLINE       0     0     0
        gptid/f2549908-2402-11ea-b7b5-ac1f6b251ca2  ONLINE       0     0     0
        gptid/707a101f-646e-11e9-8739-ac1f6b251ca2  REMOVED      0     0     0
errors: No known data errors
disks.sh - Mounted Drives on truenas.local
TrueNAS-12.0-U8.1 (4e9efc861d)
Mon Sep  5 13:53:44 PDT 2022
| Device |     DISK DESCRIPTION     |  SERIAL NUMBER   |                    GPTID                   |
| ada0   | WDC WD80EMAZ-00WJTA0     | 7SJR9K8U         | gptid/6d9df05f-646e-11e9-8739-ac1f6b251ca2
gptid/6d945c0a-646e-11e9-8739-ac1f6b251ca2 |
| ada1   | WDC WD80EMZZ-11B4FB0     | WD-CA05W1AG      | gptid/3ade1e2d-3143-11ec-9a85-ac1f6b251ca2 |
| ada2   | WDC WD80EMAZ-00WJTA0     | JEH84DKN         | gptid/f2549908-2402-11ea-b7b5-ac1f6b251ca2 |
| ada3   | WDC WD80EDAZ-11TA3A0     | VDKRN1UK         | gptid/9b328bb5-ceb1-11ea-b827-ac1f6b251ca2 |
| ada4   | WDC WD80EFAX-68LHPN0     | 7SGGEBYC         | gptid/6cfe1c23-646e-11e9-8739-ac1f6b251ca2 |
| ada5   | WDC WD80EDAZ-11TA3A0     | VGG3E3HG         | gptid/0ca962ee-da71-11ea-93a2-ac1f6b251ca2 |
| ada6   | WDC WD80EDAZ-11TA3A0     | VDKU7L8K         | gptid/4d055245-ce00-11ea-9915-ac1f6b251ca2 |
| da0    | SanDisk Cruzer Dial      | 4C530000320531122025 | gptid/d2641adc-73dd-11eb-a97e-ac1f6b251ca2 |
root@truenas[~]# glabel status
                                      Name  Status  Components
gptid/6d9df05f-646e-11e9-8739-ac1f6b251ca2     N/A  ada0p2
gptid/3ade1e2d-3143-11ec-9a85-ac1f6b251ca2     N/A  ada1p2
gptid/f2549908-2402-11ea-b7b5-ac1f6b251ca2     N/A  ada2p2
gptid/9b328bb5-ceb1-11ea-b827-ac1f6b251ca2     N/A  ada3p2
gptid/6cfe1c23-646e-11e9-8739-ac1f6b251ca2     N/A  ada4p2
gptid/0ca962ee-da71-11ea-93a2-ac1f6b251ca2     N/A  ada5p2
gptid/4d055245-ce00-11ea-9915-ac1f6b251ca2     N/A  ada6p2
gptid/d2641adc-73dd-11eb-a97e-ac1f6b251ca2     N/A  da0p1
gptid/6d945c0a-646e-11e9-8739-ac1f6b251ca2     N/A  ada0p1
I dont see the removed GPTID anywere listed? Am I blind how can I match gptid/707a101f-646e-11e9-8739-ac1f6b251ca2 REMOVED to a drive/serial number?
Thanks
Samuel Tai
Your disks.sh output looks funny. Can you report on midclt call disk.label_to_dev_disk_cache | jq?
Raggou
I figured out the issue. Ada7 was the disk that was removed/offline. I was able to match what serials were reporting vs which ones were not reporting. I basically forgot to count to 7. All set now and replacement disk is online and resilvering
