I have a dell T20 with 2 pools each of 2x1TB drives that I use to store my backups.
FreeNAS-11.1-U4
ST1000LM024 drives 1TB 2.5"
As I was doing a backup today the transfer hung and I realised the freenas error log said a drive was removed:
The drive didn't show up for me to run smartctl so I rebooted and it appeared and passed a short self test. Is the drive dead/dieing?
Is it worth doing a long self test?
If I online the disk what happens? Will freenas treat it as a brand new drive and copy over all data or will it try to copy only missing changes from the other drive?
edit: extended offline completed OK
# 1 Extended offline Completed without error 00% 443 -
FreeNAS-11.1-U4
Feb 16 17:03:51 freenas ahcich0: Timeout on slot 9 port 0 Feb 16 17:03:51 freenas ahcich0: is 00000000 cs fffff1ff ss ffffffff rs ffffffff tfd c0 serr 00000000 cmd 0000cc17 Feb 16 17:03:51 freenas (ada0:ahcich0:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 00 f8 db ac 40 5f 00 00 01 00 00 Feb 16 17:03:51 freenas (ada0:ahcich0:0:0:0): CAM status: Command timeout Feb 16 17:03:51 freenas (ada0:ahcich0:0:0:0): Retrying command Feb 16 17:03:51 freenas ahcich0: AHCI reset: device not ready after 31000ms (tfd = 00000080) [...] Feb 16 17:06:59 freenas (aprobe0:ahcich0:0:0:0): ATA_IDENTIFY. ACB: ec 00 00 00 00 40 00 00 00 00 00 00 Feb 16 17:06:59 freenas (aprobe0:ahcich0:0:0:0): CAM status: Command timeout Feb 16 17:06:59 freenas (aprobe0:ahcich0:0:0:0): Error 5, Retry was blocked Feb 16 17:06:59 freenas ada0 at ahcich0 bus 0 scbus0 target 0 lun 0 Feb 16 17:06:59 freenas ada0: <ST1000LM024 HN-M101MBB 2BA30004> s/n xx detached Feb 16 17:06:59 freenas GEOM_ELI: g_eli_write_done() failed (error=6) gptid/76525f8c-4503-11e6-bbdf-64006a5dad3c.eli[WRITE(offset=819701542912, length=1048576)] Feb 16 17:06:59 freenas GEOM_ELI: g_eli_write_done() failed (error=6) gptid/76525f8c-4503-11e6-bbdf-64006a5dad3c.eli[WRITE(offset=819702591488, length=1048576)] Feb 16 17:06:59 freenas GEOM_ELI: g_eli_write_done() failed (error=6) gptid/76525f8c-4503-11e6-bbdf-64006a5dad3c.eli[WRITE(offset=819703640064, length=1048576)] Feb 16 17:06:59 freenas GEOM_ELI: g_eli_write_done() failed (error=6) gptid/76525f8c-4503-11e6-bbdf-64006a5dad3c.eli[WRITE(offset=819704688640, length=1048576)] Feb 16 17:06:59 freenas GEOM_ELI: g_eli_write_done() failed (error=6) gptid/76525f8c-4503-11e6-bbdf-64006a5dad3c.eli[WRITE(offset=819705737216, length=1048576)] Feb 16 17:06:59 freenas GEOM_ELI: g_eli_read_done() failed (error=6) gptid/76525f8c-4503-11e6-bbdf-64006a5dad3c.eli[READ(offset=153390071808, length=4096)] Feb 16 17:06:59 freenas GEOM_ELI: g_eli_read_done() failed (error=6) gptid/76525f8c-4503-11e6-bbdf-64006a5dad3c.eli[READ(offset=270336, length=8192)] Feb 16 17:06:59 freenas GEOM_ELI: g_eli_read_done() failed (error=6) gptid/76525f8c-4503-11e6-bbdf-64006a5dad3c.eli[READ(offset=998056665088, length=8192)] Feb 16 17:06:59 freenas GEOM_ELI: g_eli_read_done() failed (error=6) gptid/76525f8c-4503-11e6-bbdf-64006a5dad3c.eli[READ(offset=998056927232, length=8192)] Feb 16 17:06:59 freenas GEOM_ELI: g_eli_write_done() failed (error=6) gptid/76525f8c-4503-11e6-bbdf-64006a5dad3c.eli[WRITE(offset=819707834368, length=1048576)] Feb 16 17:06:59 freenas GEOM_ELI: g_eli_write_done() failed (error=6) gptid/76525f8c-4503-11e6-bbdf-64006a5dad3c.eli[WRITE(offset=819706785792, length=1048576)] Feb 16 17:06:59 freenas GEOM_ELI: g_eli_write_done() failed (error=6) gptid/76525f8c-4503-11e6-bbdf-64006a5dad3c.eli[WRITE(offset=819708882944, length=524288)] Feb 16 17:07:32 freenas ahcich0: AHCI reset: device not ready after 31000ms (tfd = 00000080) [...] Feb 16 17:10:22 freenas GEOM_MIRROR: Device swap1: provider ada0p1 disconnected. Feb 16 17:10:22 freenas ZFS: vdev state changed, pool_guid=10361622149524537864 vdev_guid=8539431383270629302 Feb 16 17:10:22 freenas GEOM_ELI: Device gptid/76525f8c-4503-11e6-bbdf-64006a5dad3c.eli destroyed. Feb 16 17:10:22 freenas GEOM_ELI: Detached gptid/76525f8c-4503-11e6-bbdf-64006a5dad3c.eli on last close.
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x002f 100 100 051 Pre-fail Always - 3 2 Throughput_Performance 0x0026 252 252 000 Old_age Always - 0 3 Spin_Up_Time 0x0023 091 086 025 Pre-fail Always - 2943 4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 328 5 Reallocated_Sector_Ct 0x0033 252 252 010 Pre-fail Always - 0 7 Seek_Error_Rate 0x002e 252 252 051 Old_age Always - 0 8 Seek_Time_Performance 0x0024 252 252 015 Old_age Offline - 0 9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 442 10 Spin_Retry_Count 0x0032 252 252 051 Old_age Always - 0 11 Calibration_Retry_Count 0x0032 252 252 000 Old_age Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 330 191 G-Sense_Error_Rate 0x0022 252 252 000 Old_age Always - 0 192 Power-Off_Retract_Count 0x0022 100 100 000 Old_age Always - 17 194 Temperature_Celsius 0x0002 064 061 000 Old_age Always - 23 (Min/Max 9/39) 195 Hardware_ECC_Recovered 0x003a 100 100 000 Old_age Always - 0 196 Reallocated_Event_Count 0x0032 252 252 000 Old_age Always - 0 197 Current_Pending_Sector 0x0032 252 252 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0030 252 252 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x0036 100 100 000 Old_age Always - 1 200 Multi_Zone_Error_Rate 0x002a 100 100 000 Old_age Always - 288 223 Load_Retry_Count 0x0032 252 252 000 Old_age Always - 0 225 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 6787
