downloads for TrueNAS 9.x still available??
nrod
Hey guys, I have revived an old NAS from iX systems for a secondary backup location, it is running TrueNAS 9.2.1.2. It seems a bit flaky at times and I'd like to update the OS. It's old enough I assume it's not going to be supported for ver 12+, but was hoping to get it a bit newer than where it's at.
I attempted to update to Freenas 9.3 and it returned that 'Truenas does not equal Freenas.' I'd prefer to just update the existing OS if possible and don't want to invest a ton of time in it as it generally serves its purpose. Are there still Truenas 9.x or 10.x downloads available where I can make a small OS jump? I can't find them anywhere...
Redcoat
All versions are available here http://archive.freenas.org/
You will see that 10 doesn't exist there - it was withdrawn. There are a number of threads here discussing updating from old versions which detail appropriate stepping processes.
Posting the NAS specs may enable some comments about upgrade possibilities.
ornias
If I might ask, why did you asume it wouldn't be compatible with TrueNAS Core 12?
Any drivers that are removed from FreeBSD?
nrod
Just assumed due to age...
GEOM_RAID: Intel-ad3bdd18 82801 SATA RAID Controller
Intel(R) Xeon(R) CPU E5645 @ 2.40GHz
Intel 5520/5500 chipset
Intel 82576 Gigabit Network controller
Matrox graphics MGA G200eW WPCM450
any other hardware specs needed?
I've stumbled across this before, all FreeNAS versions sans v10. when I attempted to update from the TrueNAS gui firmware update button to a freenas 9.3 version it returned 'Truenas does not equal Freenas' and did not update. I suppose I could do it manually.... the nature of my question was are there Truenas downloads available that I could just use the 'firmware update' button to update more automatically.
