Wolfeman0101
- Jun 14, 2012
I have 16GB of RAM. Also my proc seems like it's barely being used right?
What's wrong with it? Yes, you have 16GB and why would you be using a lot of processor?I have 16GB of RAM. Also my proc seems like it's barely being used right?
I'm leaning that way too but how do I check that?40+ hours? Almost sounds like IO bottleneck to me?
Look for problematic disks:I'm leaning that way too but how do I check that?
smartctl -q noserial -a /dev/adaX
cat /boot/loader.conf.local zpool list zfs list
gstat -I1s -f 'a?da[0-9]+$'
smartctl 5.43 2012-06-30 r3573 [FreeBSD 8.3-RELEASE-p5 amd64] (local build)
Copyright (C) 2002-12 by Bruce Allen, http://smartmontools.sourceforge.net
Model Family: Hitachi Deskstar 5K3000
Device Model: Hitachi HDS5C3020ALA632
Firmware Version: ML6OA800
User Capacity: 2,000,398,934,016 bytes [2.00 TB]
Sector Size: 512 bytes logical/physical
ATA Version is: 8
ATA Standard is: ATA-8-ACS revision 4
Local Time is: Tue Feb 12 20:58:06 2013 PST
SMART support is: Enabled
General SMART Values:
Offline data collection status: (0x84) Offline data collection activity
was suspended by an interrupting command from host.
been run.
data collection: (22966) seconds.
capabilities: (0x5b) SMART execute Offline immediate.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 383) minutes.
SCT capabilities: (0x003d) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x000b 093 093 016 Pre-fail Always - 1835011
2 Throughput_Performance 0x0005 133 133 054 Pre-fail Offline - 106
3 Spin_Up_Time 0x0007 166 166 024 Pre-fail Always - 299 (Average 361)
4 Start_Stop_Count 0x0012 100 100 000 Old_age Always - 83
5 Reallocated_Sector_Ct 0x0033 100 100 005 Pre-fail Always - 0
7 Seek_Error_Rate 0x000b 100 100 067 Pre-fail Always - 0
8 Seek_Time_Performance 0x0005 146 146 020 Pre-fail Offline - 29
9 Power_On_Hours 0x0012 100 100 000 Old_age Always - 5466
10 Spin_Retry_Count 0x0013 100 100 060 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 82
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 247
193 Load_Cycle_Count 0x0012 100 100 000 Old_age Always - 247
194 Temperature_Celsius 0x0002 176 176 000 Old_age Always - 34 (Min/Max 22/47)
196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0
197 Current_Pending_Sector 0x0022 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0008 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x000a 200 200 000 Old_age Always - 0
SMART Error Log Version: 1
No Errors Logged
# 1 Short offline Completed without error 00% 4994 -
# 2 Short offline Completed without error 00% 4970 -
# 3 Short offline Completed without error 00% 4946 -
# 4 Short offline Completed without error 00% 4922 -
# 5 Short offline Completed without error 00% 4898 -
# 6 Short offline Completed without error 00% 4874 -
# 7 Short offline Completed without error 00% 4850 -
# 8 Short offline Completed without error 00% 4826 -
# 9 Short offline Completed without error 00% 4802 -
#10 Short offline Completed without error 00% 4778 -
#11 Short offline Completed without error 00% 4754 -
#12 Short offline Completed without error 00% 4730 -
#13 Short offline Completed without error 00% 4706 -
#14 Short offline Completed without error 00% 4682 -
#15 Short offline Completed without error 00% 4658 -
#16 Short offline Completed without error 00% 4634 -
#17 Short offline Completed without error 00% 4610 -
#18 Short offline Completed without error 00% 4586 -
#19 Short offline Completed without error 00% 4562 -
#20 Short offline Completed without error 00% 4538 -
#21 Short offline Completed without error 00% 4515 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
If Selective self-test is pending on power-up, resume after 0 minute delay.smartctl 5.43 2012-06-30 r3573 [FreeBSD 8.3-RELEASE-p5 amd64] (local build)
ATA Version is: 8
Local Time is: Tue Feb 12 20:58:22 2013 PST
been run.
data collection: (23136) seconds.
command.
power-saving mode.
recommended polling time: ( 386) minutes.
1 Raw_Read_Error_Rate 0x000b 100 100 016 Pre-fail Always - 0
2 Throughput_Performance 0x0005 132 132 054 Pre-fail Offline - 108
3 Spin_Up_Time 0x0007 185 185 024 Pre-fail Always - 234 (Average 360)
4 Start_Stop_Count 0x0012 100 100 000 Old_age Always - 82
194 Temperature_Celsius 0x0002 171 171 000 Old_age Always - 35 (Min/Max 23/46)
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Model Family: Western Digital Caviar Green (Adv. Format)
Device Model: WDC WD20EARX-00PASB0
Firmware Version: 51.0AB51
ATA Version is: 8
ATA Standard is: Exact ATA specification draft version not indicated
Local Time is: Tue Feb 12 20:58:59 2013 PST
been run.
data collection: (40860) seconds.
command.
power-saving mode.
recommended polling time: ( 394) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x3035) SCT Status supported.
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 5
3 Spin_Up_Time 0x0027 222 164 021 Pre-fail Always - 3891
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 84
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 094 094 000 Old_age Always - 5069
10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 79
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 74
193 Load_Cycle_Count 0x0032 195 195 000 Old_age Always - 16818
194 Temperature_Celsius 0x0022 115 102 000 Old_age Always - 35
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 200 200 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0
No Errors Logged
# 1 Short offline Completed without error 00% 4599 -
# 2 Short offline Completed without error 00% 4576 -
# 3 Short offline Completed without error 00% 4552 -
# 4 Short offline Completed without error 00% 4528 -
# 5 Short offline Completed without error 00% 4504 -
# 6 Short offline Completed without error 00% 4480 -
# 7 Short offline Completed without error 00% 4456 -
# 8 Short offline Completed without error 00% 4432 -
# 9 Short offline Completed without error 00% 4408 -
#10 Short offline Completed without error 00% 4384 -
#11 Short offline Completed without error 00% 4360 -
#12 Short offline Completed without error 00% 4336 -
#13 Short offline Completed without error 00% 4312 -
#14 Short offline Completed without error 00% 4289 -
#15 Short offline Completed without error 00% 4265 -
#16 Short offline Completed without error 00% 4241 -
#17 Short offline Completed without error 00% 4217 -
#18 Short offline Completed without error 00% 4193 -
#19 Short offline Completed without error 00% 4169 -
#20 Short offline Completed without error 00% 4145 -
#21 Short offline Completed without error 00% 4122 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
ATA Version is: 8
Local Time is: Tue Feb 12 20:59:03 2013 PST
been run.
data collection: (39900) seconds.
command.
power-saving mode.
recommended polling time: ( 384) minutes.
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 228 168 021 Pre-fail Always - 3575
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 85
9 Power_On_Hours 0x0032 094 094 000 Old_age Always - 5071
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 73
193 Load_Cycle_Count 0x0032 195 195 000 Old_age Always - 17345
194 Temperature_Celsius 0x0022 116 101 000 Old_age Always - 34
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
200 Multi_Zone_Error_Rate 0x0008 100 253 000 Old_age Offline - 0
No Errors Logged
# 1 Short offline Completed without error 00% 4600 -
# 2 Short offline Completed without error 00% 4577 -
# 3 Short offline Completed without error 00% 4553 -
# 4 Short offline Completed without error 00% 4529 -
# 5 Short offline Completed without error 00% 4505 -
# 6 Short offline Completed without error 00% 4481 -
# 7 Short offline Completed without error 00% 4457 -
# 8 Short offline Completed without error 00% 4433 -
# 9 Short offline Completed without error 00% 4409 -
#10 Short offline Completed without error 00% 4385 -
#11 Short offline Completed without error 00% 4361 -
#12 Short offline Completed without error 00% 4337 -
#13 Short offline Completed without error 00% 4313 -
#15 Short offline Completed without error 00% 4266 -
#16 Short offline Completed without error 00% 4242 -
#17 Short offline Completed without error 00% 4218 -
#18 Short offline Completed without error 00% 4194 -
#19 Short offline Completed without error 00% 4170 -
#20 Short offline Completed without error 00% 4146 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
ATA Version is: 8
Local Time is: Tue Feb 12 20:59:23 2013 PST
been run.
data collection: (38460) seconds.
command.
power-saving mode.
recommended polling time: ( 371) minutes.
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 1
3 Spin_Up_Time 0x0027 223 163 021 Pre-fail Always - 3808
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 81
9 Power_On_Hours 0x0032 094 094 000 Old_age Always - 5067
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 71
193 Load_Cycle_Count 0x0032 195 195 000 Old_age Always - 16865
194 Temperature_Celsius 0x0022 116 098 000 Old_age Always - 34
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 2
No Errors Logged
# 1 Short offline Completed without error 00% 4596 -
# 2 Short offline Completed without error 00% 4572 -
# 3 Short offline Completed without error 00% 4548 -
# 4 Short offline Completed without error 00% 4524 -
# 5 Short offline Completed without error 00% 4501 -
# 6 Short offline Completed without error 00% 4477 -
# 7 Short offline Completed without error 00% 4453 -
# 8 Short offline Completed without error 00% 4429 -
# 9 Short offline Completed without error 00% 4405 -
#10 Short offline Completed without error 00% 4381 -
#11 Short offline Completed without error 00% 4357 -
#12 Short offline Completed without error 00% 4333 -
#13 Short offline Completed without error 00% 4309 -
#14 Short offline Completed without error 00% 4285 -
#15 Short offline Completed without error 00% 4262 -
#16 Short offline Completed without error 00% 4238 -
#17 Short offline Completed without error 00% 4214 -
#18 Short offline Completed without error 00% 4190 -
#19 Short offline Completed without error 00% 4166 -
#20 Short offline Completed without error 00% 4142 -
#21 Short offline Completed without error 00% 4134 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
ATA Version is: 8
Local Time is: Tue Feb 12 20:59:32 2013 PST
been run.
data collection: (38160) seconds.
command.
power-saving mode.
recommended polling time: ( 368) minutes.
3 Spin_Up_Time 0x0027 245 168 021 Pre-fail Always - 2733
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 80
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 75
193 Load_Cycle_Count 0x0032 196 196 000 Old_age Always - 14989
No Errors Logged
# 1 Short offline Completed without error 00% 4597 -
# 2 Short offline Completed without error 00% 4573 -
# 3 Short offline Completed without error 00% 4549 -
# 4 Short offline Completed without error 00% 4525 -
# 9 Short offline Completed without error 00% 4406 -
#10 Short offline Completed without error 00% 4382 -
#11 Short offline Completed without error 00% 4358 -
#12 Short offline Completed without error 00% 4334 -
#13 Short offline Completed without error 00% 4310 -
#14 Short offline Completed without error 00% 4286 -
#18 Short offline Completed without error 00% 4191 -
#19 Short offline Completed without error 00% 4167 -
#20 Short offline Completed without error 00% 4143 -
#21 Short offline Completed without error 00% 4140 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
If Selective self-test is pending on power-up, resume after 0 minute delay.vfs.zfs.arc_max="10400455157" # Generated by autotune vm.kmem_size_max="14445076608" # Generated by autotune vm.kmem_size="11556061286" # Generated by autotune kern.ipc.nmbclusters="20000" # Generated by autotune
NAME SIZE ALLOC FREE CAP DEDUP HEALTH ALTROOT Vol1 10.9T 9.97T 928G 91% 1.00x ONLINE /mnt
NAME USED AVAIL REFER MOUNTPOINT Vol1 6.64T 502G 6.64T /mnt/Vol1 Vol1/Jail 700M 502G 700M /mnt/Vol1/Jail Vol1/Plugins 3.44G 502G 3.44G /mnt/Vol1/Plugins
We can stop looking. You are over 90% full. This is sufficient to cause your excessive scrub times. The pool has switched to space based optimization which as you noticed hurts.zpool list
Code:NAME SIZE ALLOC FREE CAP DEDUP HEALTH ALTROOT Vol1 10.9T 9.97T 928G 91% 1.00x ONLINE /mnt
You didn't mention what version of FreeNAS you are using, but you could likely increase some of these to allow ZFS more RAM. Based on your top you hadn't maxed out yet so you may not need to.cat /boot/loader.conf.local
Code:vfs.zfs.arc_max="10400455157" # Generated by autotune vm.kmem_size_max="14445076608" # Generated by autotune vm.kmem_size="11556061286" # Generated by autotune kern.ipc.nmbclusters="20000" # Generated by autotune
What can I do? I'm out of onboard SATA ports so I can't add more drives. I have 6x2TB in RAIDZ2. I believe there were issues when I had a lot more free space. What is the recommended % free?We can stop looking. You are over 90% full. This is sufficient to cause your excessive scrub times. The pool has switched to space based optimization which as you noticed hurts.
I was running a daily drive test from a script I found in this post. http://forums.freenas.org/showthrea...orting-via-email&p=49604&viewfull=1#post49604They all look fine aside from the pointless daily short tests. I'd switch that to a bi-monthly or weekly long test. How are ada4 & ada5 connected? They both have 199 UDMA_CRC_Error_Count of 2. It would need to be higher to be a factor though. I'd watch it and make sure it doesn't increase further.
[root@nibbler] /dev# gstat -I1s -f 'a?da[0-9]+$'
dT: 1.001s w: 1.000s filter: a?da[0-9]+$
L(q) ops/s r/s kBps ms/r w/s kBps ms/w %busy Name
10 257 68 6778 28.6 188 14650 9.6 54.5| ada0
10 258 68 6854 34.3 189 14670 10.2 52.0| ada1
10 289 54 5059 57.9 234 16848 8.5 68.9| ada2
10 279 43 3808 14.5 235 16784 6.3 33.1| ada3
9 235 59 6150 128.8 174 14023 13.9 111.9| ada4
10 233 58 5727 119.1 173 13939 11.7 102.9| ada5
0 2 0 0 0.0 2 8 463.4 46.5| da0
