I'm trying to set up Frigate in a Docker container. The recommended Docker container looks like:
I don't see an option to give the --mount type=tmpfs,target=/tmp/cache,tmpfs-size=1000000000 and other arguments in the SCALE UI, however.
Is there a way to do this?
docker run -d \
--name frigate \
--restart=unless-stopped \
--mount type=tmpfs,target=/tmp/cache,tmpfs-size=1000000000 \
--device /dev/bus/usb:/dev/bus/usb \
--device /dev/dri/renderD128 \
--shm-size=64m \
-v /path/to/your/storage:/media/frigate \
-v /path/to/your/config.yml:/config/config.yml \
-v /etc/localtime:/etc/localtime:ro \
-e FRIGATE_RTSP_PASSWORD='password' \
-p 5000:5000 \
-p 8554:8554 \
-p 8555:8555/tcp \
-p 8555:8555/udp \
ghcr.io/blakeblackshear/frigate:stable
