Disks not showing up in truenas
Deadalus
Very new to TrueNas, I have managed to install it and get to the web interface, however whenever I try to put in an HDD into the hot-swap bays nothing shows up under disks, and I am not sure why they wouldn't, I just wanted to make sure I can see the drive from each of the trays before I start making any pools. but thus far I'm not seeing anything.
My setup:
- RROYJJ 4U Rackmount Server Case Chassis with 24 Hot-Swappable SATA/SAS Drive Bays
- LRSACX36 24 port 12 G SAS expander card
- EVGA x58 SLI3 motherboard
- Intel(R) Core(TM) i7 CPU 950 @ 3.07GHz
- 24GB RAM
Any pointer/direction would be greatly appreciated.
thanks.
Redcoat
Welcome to the forums!
With one or more drives in the bays, from the shell run camcontrol devlist and report the output here.
Deadalus
typed it out because it wouldn't copy past for me right.
<Samsung SSD 850 EVO 500GB EMT02B6Q> at scbus8 target 0 lun 0 (ada0,pass0)
<WD Blue SA510 2.5 500GB 52020100> at scbus9 target 0 lun 0 (ada1,pass1)
<AHCI SGPIO Enclosure 2.00 00001> at scbus14 target 0 lun 0 (ses0,pass2)
Deadalus
i should mention that both the samsung and the WD blue are connected directly to the motherboard via SATA cables and not through the back plane.
Redcoat
Well, points to a backplane or expander card issue by the sound of things I guess.
