Pierremenard
- Mar 13, 2012
Hello, I have raidz1 zpool on my freenas 9.1.1 release.
Since yesterday one of the disk of the zpool go "removed".
Can someone help me to understand which is faulty, the disk or the controller?
This is the output of zpool
This is the output of gpart list
This is the content of dev directory (from where I see that the drive is still available)
and lastly this is the output of dmesg
Thank you very much in advance
F.
pool: Funes
state: DEGRADED
status: One or more devices has been removed by the administrator.
Sufficient replicas exist for the pool to continue functioning in a
degraded state.
action: Online the device using 'zpool online' or replace the device with
'zpool replace'.
scan: resilvered 2.84M in 0h1m with 0 errors on Fri Oct 25 13:11:58 2013
NAME STATE READ WRITE CKSUM
Funes DEGRADED 0 0 0
raidz1-0 DEGRADED 0 0 0
7403170072441323061 REMOVED 0 0 0 was /dev/gptid/90f1a311-fce1-11e2-9d79-00138f609fb1
gptid/cc0ad478-b0e3-11e1-afff-00138f609fb1 ONLINE 0 0 0
ada2p2 ONLINE 0 0 0
gptid/46587c8f-18b7-11e3-abb2-00138f609fb1 ONLINE 0 0 0
errors: No known data errorsThis is the output of gpart list
Geom name: ada1 modified: false state: OK fwheads: 16 fwsectors: 63 last: 1953525134 first: 34 entries: 128 scheme: GPT Providers: 1. Name: ada1p1 Mediasize: 2147483648 (2.0G) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r1w1e1 rawuuid: 461dd016-18b7-11e3-abb2-00138f609fb1 rawtype: 516e7cb5-6ecf-11d6-8ff8-00022d09712b label: (null) length: 2147483648 offset: 65536 type: freebsd-swap index: 1 end: 4194431 start: 128 2. Name: ada1p2 Mediasize: 998057319936 (929G) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r1w1e2 rawuuid: 46587c8f-18b7-11e3-abb2-00138f609fb1 rawtype: 516e7cba-6ecf-11d6-8ff8-00022d09712b label: (null) length: 998057319936 offset: 2147549184 type: freebsd-zfs index: 2 end: 1953525134 start: 4194432 Consumers: 1. Name: ada1 Mediasize: 1000204886016 (931G) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r2w2e5 Geom name: ada2 modified: false state: OK fwheads: 16 fwsectors: 63 last: 1953525134 first: 34 entries: 128 scheme: GPT Providers: 1. Name: ada2p1 Mediasize: 2147483648 (2.0G) Sectorsize: 512 Stripesize: 0 Stripeoffset: 65536 Mode: r1w1e1 rawuuid: cc7533f7-b0e3-11e1-afff-00138f609fb1 rawtype: 516e7cb5-6ecf-11d6-8ff8-00022d09712b label: (null) length: 2147483648 offset: 65536 type: freebsd-swap index: 1 end: 4194431 start: 128 2. Name: ada2p2 Mediasize: 998057319936 (929G) Sectorsize: 512 Stripesize: 0 Stripeoffset: 2147549184 Mode: r1w1e1 rawuuid: cc7dfa45-b0e3-11e1-afff-00138f609fb1 rawtype: 516e7cba-6ecf-11d6-8ff8-00022d09712b label: (null) length: 998057319936 offset: 2147549184 type: freebsd-zfs index: 2 end: 1953525134 start: 4194432 Consumers: 1. Name: ada2 Mediasize: 1000204886016 (931G) Sectorsize: 512 Mode: r2w2e4 Geom name: ada3 modified: false state: OK fwheads: 16 fwsectors: 63 last: 1953525134 first: 34 entries: 128 scheme: GPT Providers: 1. Name: ada3p1 Mediasize: 2147483648 (2.0G) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r1w1e1 rawuuid: cbecd89e-b0e3-11e1-afff-00138f609fb1 rawtype: 516e7cb5-6ecf-11d6-8ff8-00022d09712b label: (null) length: 2147483648 offset: 65536 type: freebsd-swap index: 1 end: 4194431 start: 128 2. Name: ada3p2 Mediasize: 998057319936 (929G) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r1w1e2 rawuuid: cc0ad478-b0e3-11e1-afff-00138f609fb1 rawtype: 516e7cba-6ecf-11d6-8ff8-00022d09712b label: (null) length: 998057319936 offset: 2147549184 type: freebsd-zfs index: 2 end: 1953525134 start: 4194432 Consumers: 1. Name: ada3 Mediasize: 1000204886016 (931G) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r2w2e5 Geom name: da0 modified: false state: OK fwheads: 255 fwsectors: 63 last: 31266815 first: 63 entries: 4 scheme: MBR Providers: 1. Name: da0s1 Mediasize: 988291584 (942M) Sectorsize: 512 Stripesize: 0 Stripeoffset: 32256 Mode: r1w0e1 attrib: active rawtype: 165 length: 988291584 offset: 32256 type: freebsd index: 1 end: 1930319 start: 63 2. Name: da0s2 Mediasize: 988291584 (942M) Sectorsize: 512 Stripesize: 0 Stripeoffset: 988356096 Mode: r0w0e0 rawtype: 165 length: 988291584 offset: 988356096 type: freebsd index: 2 end: 3860639 start: 1930383 3. Name: da0s3 Mediasize: 1548288 (1.5M) Sectorsize: 512 Stripesize: 0 Stripeoffset: 1976647680 Mode: r0w0e0 rawtype: 165 length: 1548288 offset: 1976647680 type: freebsd index: 3 end: 3863663 start: 3860640 4. Name: da0s4 Mediasize: 21159936 (20M) Sectorsize: 512 Stripesize: 0 Stripeoffset: 1978195968 Mode: r1w1e2 rawtype: 165 length: 21159936 offset: 1978195968 type: freebsd index: 4 end: 3904991 start: 3863664 Consumers: 1. Name: da0 Mediasize: 16008609792 (14G) Sectorsize: 512 Mode: r2w1e4 Geom name: da0s1 modified: false state: OK fwheads: 255 fwsectors: 63 last: 1930256 first: 0 entries: 8 scheme: BSD Providers: 1. Name: da0s1a Mediasize: 988283392 (942M) Sectorsize: 512 Stripesize: 0 Stripeoffset: 40448 Mode: r1w0e1 rawtype: 0 length: 988283392 offset: 8192 type: !0 index: 1 end: 1930256 start: 16 Consumers: 1. Name: da0s1 Mediasize: 988291584 (942M) Sectorsize: 512 Stripesize: 0 Stripeoffset: 32256 Mode: r1w0e1 Geom name: ada0 modified: false state: OK fwheads: 16 fwsectors: 63 last: 1953525134 first: 34 entries: 128 scheme: GPT Providers: 1. Name: ada0p1 Mediasize: 2147483648 (2.0G) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r0w0e0 rawuuid: 90e470dd-fce1-11e2-9d79-00138f609fb1 rawtype: 516e7cb5-6ecf-11d6-8ff8-00022d09712b label: (null) length: 2147483648 offset: 65536 type: freebsd-swap index: 1 end: 4194431 start: 128 2. Name: ada0p2 Mediasize: 998057319936 (929G) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r0w0e0 rawuuid: 90f1a311-fce1-11e2-9d79-00138f609fb1 rawtype: 516e7cba-6ecf-11d6-8ff8-00022d09712b label: (null) length: 998057319936 offset: 2147549184 type: freebsd-zfs index: 2 end: 1953525134 start: 4194432 Consumers: 1. Name: ada0 Mediasize: 1000204886016 (931G) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r0w0e0
./ ../ acpi ad10@ ad10p1@ ad10p1.eli@ ad10p2@ ad4@ ad4p1@ ad4p2@ ad6@ ad6p1@ ad6p1.eli@ ad6p2@ ad8@ ad8p1@ ad8p1.eli@ ad8p2@ ada0 ada0p1 ada0p2 ada1 ada1p1 ada1p1.eli ada1p2 ada2 ada2p1 ada2p1.eli ada2p2 ada3 ada3p1 ada3p1.eli ada3p2 atkbd0 audit bpf bpf0@ console consolectl crypto ctty cuaU0 cuaU0.init cuaU0.lock cuau0 cuau0.init cuau0.lock da0 da0s1 da0s1a da0s2 da0s3 da0s4 devctl devstat dtrace/ dumpdev@ fd/ fido geom.ctl ggctl gptid/ io kbd0@ kbd1@ kbdmux0 klog kmem log@ lpt0 lpt0.ctl md0 md1 md2 mdctl mem nfslock null pass0 pass1 pass2 pass3 pass4 pci ptmx pts/ random snp stderr@ stdin@ stdout@ sysmouse ttyU0 ttyU0.init ttyU0.lock ttyu0 ttyu0.init ttyu0.lock ttyv0 ttyv1 ttyv2 ttyv3 ttyv4 ttyv5 ttyv6 ttyv7 ttyv8 ttyv9 ttyva ttyvb ttyvc ttyvd ttyve ttyvf ufs/ ufssuspend ugen0.1@ ugen0.2@ ugen1.1@ ugen1.2@ urandom@ usb/ usbctl xpt0 zero zfs
ada2: Previously was known as ad8
ada3 at ata5 bus 0 scbus3 target 0 lun 0
ada3: <ST1000DM003-9YN162 CC4B> ATA-8 SATA 3.x device
ada3: 150.000MB/s transfers (SATA 1.x, UDMA5, PIO 8192bytes)
ada3: 953869MB (1953525168 512 byte sectors: 16H 63S/T 16383C)
ada3: quirks=0x1<4K>
ada3: Previously was known as ad10
SMP: AP CPU #1 Launched!
uhub0: 8 ports with 8 removable, self powered
Root mount waiting for: usbus1
uhub1: 8 ports with 8 removable, self powered
ugen1.2: <SanDisk> at usbus1
umass0: <SanDisk Cruzer, class 0/0, rev 2.00/1.02, addr 2> on usbus1
da0 at umass-sim0 bus 0 scbus4 target 0 lun 0
da0: <SanDisk Cruzer 1.10> Removable Direct Access SCSI-2 device
da0: 40.000MB/s transfers
da0: 15267MB (31266816 512 byte sectors: 255H 63S/T 1946C)
da0: quirks=0x2<NO_6_BYTE>
Trying to mount root from ufs:/dev/ufs/FreeNASs1a [ro]...
ugen0.2: <Prolific Technology Inc.> at usbus0
uplcom0: <Prolific Technology Inc. USB-Serial Controller, class 0/0, rev 1.10/3.00, addr 2> on usbus0
(aprobe0:ata2:0:0:0): SETFEATURES SET TRANSFER MODE. ACB: ef 03 00 00 00 40 00 00 00 00 45 00
(aprobe0:ata2:0:0:0): CAM status: Unconditionally Re-queue Request
(aprobe0:ata2:0:0:0): Error 5, Retry was blocked
ZFS NOTICE: Prefetch is disabled by default if less than 4GB of RAM is present;
to enable, add "vfs.zfs.prefetch_disable=0" to /boot/loader.conf.
ZFS filesystem version: 5
ZFS storage pool version: features support (5000)
GEOM_RAID5: Module loaded, version 1.1.20110927.40 (rev 00ce00e5abb4)
(aprobe0:ata2:0:0:0): ATA_IDENTIFY. ACB: ec 00 00 00 00 40 00 00 00 00 00 00
GEOM_ELI: Device ada1p1.eli created.
GEOM_ELI: Encryption: AES-XTS 256
GEOM_ELI: Crypto: software
GEOM_ELI: Device ada2p1.eli created.
GEOM_ELI: Device ada3p1.eli created.
GEOM_ELI: Device ada0p1.eli created.
(ada0:ata2:0:0:0): READ_DMA. ACB: c8 00 a0 02 40 40 00 00 00 00 e0 00
(ada0:ata2:0:0:0): CAM status: ATA Status Error
(ada0:ata2:0:0:0): ATA status: 51 (DRDY SERV ERR), error: 40 (UNC )
(ada0:ata2:0:0:0): RES: 51 40 a0 02 40 00 00 00 00 cf 00
(ada0:ata2:0:0:0): Retrying command
----cut same error multiple time----
(ada0:ata2:0:0:0): RES: 51 40 b8 02 40 00 00 00 00 bf 00
(ada0:ata2:0:0:0): Error 5, Retries exhausted
Solaris: WARNING: Disk, '/dev/gptid/90f1a311-fce1-11e2-9d79-00138f609fb1', has a block alignment that is larger than the pool's alignment
bridge0: Ethernet address: 02:81:f4:ec:68:00
bridge0: link state changed to UP
nfe0: promiscuous mode enabled
epair0a: Ethernet address: 02:71:9e:00:07:0a
epair0b: Ethernet address: 02:71:9e:00:08:0b
epair0a: link state changed to UP
epair0b: link state changed to UP
epair0a: promiscuous mode enabled
epair1a: Ethernet address: 02:b8:09:00:08:0a
epair1b: Ethernet address: 02:b8:09:00:09:0b
epair1a: link state changed to UP
epair1b: link state changed to UP
epair1a: promiscuous mode enabled
arp: 192.168.5.99 moved from 02:71:9e:00:07:0a to 00:13:8f:60:9f:b1 on epair0b
(ada0:ata2:0:0:0): lost device
(ada0:ata2:0:0:0): removing device entry
ada0 at ata2 bus 0 scbus0 target 0 lun 0
ada0: <WDC WD10EARS-00Y5B1 80.00A80> ATA-8 SATA 2.x device
ada0: 150.000MB/s transfers (SATA 1.x, UDMA5, PIO 8192bytes)
ada0: 953869MB (1953525168 512 byte sectors: 16H 63S/T 16383C)
ada0: quirks=0x1<4K>
ada0: Previously was known as ad4
arp: 192.168.5.99 moved from 00:13:8f:60:9f:b1 to 02:71:9e:00:07:0a on epair0b
F.
