I am new to FreeNas.
I am looking for some advise on setting up a test system for evaluating FreeNas 9.3
System Informatoin:
SuperMicro 6027R-WRF
* 256G RAM
* 2 512G sata disks for the OS
* 20 4TB drives
System activity:
* Very heavy read activity of small files via NFS
* Very heavy writes on NFS
I will be using RaidZ2 for the extra protection and will be setting up 2-10 disk VDEV pools.
My questions are the following:
1. since I have so much memory, should I used it instead of L2ARC to gain some increased performance
2. The system is on UPS; therefore I am thinking that I can avoid using a ZIL log and turn off sync n each pool for NFS activity.
Does the above sound right or should I be doing something else? I'm looking to improve read/write performance via NFS but cannot afford to use RAID0+1 mirroring for this application.
Thanks!
System Informatoin:
* 256G RAM
* 20 4TB drives
System activity:
Thanks!
