jimnastics
- Feb 28, 2016
I had been running a 2 x 3TB (both WD Red) mirrored pool in a HP Proliant Gen8 up until a month or so ago when one of the disks died (genuine SMART confirmed death) after nearly 5 years of constant use. After some reasearch I replaced the disk with a 4tb WD Red, on the understanding that the pool would stay as 3TB until I upgraded the other disk to a 4TB (fine with me). However, since I installed the new disk, it has been throwing write errors and faulting at least once a week. On a reboot the disk is resilvered and all is fine until it happens again eventually. I have tried removing and reseating the drive, cleaned the connections on the backplane, tried the drive in the other bays, but it keeps happening.
Here are the results of long SMART tests which seem fine to me, can anyone spot anything of concern?
Is there a chance that combing a new 4tb drive with the older 3tb is causing problems? Here is the SMART output for the old healthy drive:
root@freenas:~ # smartctl -a /dev/ada1 smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.1-STABLE amd64] (local build) Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Device Model: WDC WD40EFZX-68AWUN0 Serial Number: WD-WX12DA1PZTKA LU WWN Device Id: 5 0014ee 214ba5d34 Firmware Version: 81.00B81 User Capacity: 4,000,787,030,016 bytes [4.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 5400 rpm Form Factor: 3.5 inches Device is: Not in smartctl database [for details use: -P showall] ATA Version is: ACS-3 T13/2161-D revision 5 SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Fri Mar 25 12:06:23 2022 GMT SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x00) Offline data collection activity was never started. Auto Offline Data Collection: Disabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: (44640) seconds. Offline data collection capabilities: (0x11) SMART execute Offline immediate. No Auto Offline data collection support. Suspend Offline collection upon new command. No Offline surface scan supported. Self-test supported. No Conveyance Self-test supported. No Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 473) minutes. SCT capabilities: (0x303d) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0 3 Spin_Up_Time 0x0027 224 224 021 Pre-fail Always - 3791 4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 11 5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0 7 Seek_Error_Rate 0x002e 100 253 000 Old_age Always - 0 9 Power_On_Hours 0x0032 099 099 000 Old_age Always - 929 10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0 11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 10 192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 8 193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 3 194 Temperature_Celsius 0x0022 124 115 000 Old_age Always - 26 196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0 197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0 200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0 SMART Error Log Version: 1 ATA Error Count: 1 CR = Command Register [HEX] FR = Features Register [HEX] SC = Sector Count Register [HEX] SN = Sector Number Register [HEX] CL = Cylinder Low Register [HEX] CH = Cylinder High Register [HEX] DH = Device/Head Register [HEX] DC = Device Command Register [HEX] ER = Error register [HEX] ST = Status register [HEX] Powered_Up_Time is measured from power on, and printed as DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes, SS=sec, and sss=millisec. It "wraps" after 49.710 days. Error 1 occurred at disk power-on lifetime: 928 hours (38 days + 16 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 04 61 00 00 00 00 40 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- e3 00 00 00 00 00 40 08 00:05:00.793 IDLE 2f 00 01 10 00 00 00 08 00:04:21.130 READ LOG EXT 2f 00 01 10 00 00 00 08 00:04:21.126 READ LOG EXT SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Extended offline Completed without error 00% 928 - # 2 Extended offline Completed without error 00% 857 - # 3 Short offline Completed without error 00% 777 - # 4 Extended offline Completed without error 00% 736 - # 5 Extended offline Completed without error 00% 622 - # 6 Short offline Completed without error 00% 542 - # 7 Short offline Completed without error 00% 422 - # 8 Extended offline Completed without error 00% 287 - # 9 Short offline Completed without error 00% 207 - #10 Short offline Completed without error 00% 39 - Selective Self-tests/Logging not supported
root@freenas:~ # smartctl -a /dev/ada0 smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.1-STABLE amd64] (local build) Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Western Digital Red Device Model: WDC WD30EFRX-68EUZN0 Serial Number: WD-WCC4N4JH6ZXY LU WWN Device Id: 5 0014ee 2b76dcbd4 Firmware Version: 82.00A82 User Capacity: 3,000,592,982,016 bytes [3.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 5400 rpm Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-2 (minor revision not indicated) SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Fri Mar 25 12:52:02 2022 GMT SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x00) Offline data collection activity was never started. Auto Offline Data Collection: Disabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: (39120) seconds. Offline data collection capabilities: (0x7b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 393) minutes. Conveyance self-test routine recommended polling time: ( 5) minutes. SCT capabilities: (0x703d) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 9 3 Spin_Up_Time 0x0027 198 180 021 Pre-fail Always - 5100 4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 106 5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0 7 Seek_Error_Rate 0x002e 100 253 000 Old_age Always - 0 9 Power_On_Hours 0x0032 029 029 000 Old_age Always - 52483 10 Spin_Retry_Count 0x0032 100 100 000 Old_age Always - 0 11 Calibration_Retry_Count 0x0032 100 100 000 Old_age Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 106 192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 72 193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 258 194 Temperature_Celsius 0x0022 122 107 000 Old_age Always - 28 196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0 197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0 200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0 SMART Error Log Version: 1 ATA Error Count: 133 (device log contains only the most recent five errors) CR = Command Register [HEX] FR = Features Register [HEX] SC = Sector Count Register [HEX] SN = Sector Number Register [HEX] CL = Cylinder Low Register [HEX] CH = Cylinder High Register [HEX] DH = Device/Head Register [HEX] DC = Device Command Register [HEX] ER = Error register [HEX] ST = Status register [HEX] Powered_Up_Time is measured from power on, and printed as DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes, SS=sec, and sss=millisec. It "wraps" after 49.710 days. Error 133 occurred at disk power-on lifetime: 51281 hours (2136 days + 17 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 04 61 00 80 84 00 40 Device Fault; Error: ABRT at LBA = 0x00008480 = 33920 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- ca 00 00 80 84 00 40 08 1d+17:25:35.147 WRITE DMA ca 00 00 80 84 00 40 08 1d+17:25:35.144 WRITE DMA ca 00 00 80 84 00 40 08 1d+17:25:35.142 WRITE DMA ca 00 00 80 84 00 40 08 1d+17:25:35.139 WRITE DMA ca 00 00 80 84 00 40 08 1d+17:25:35.136 WRITE DMA Error 132 occurred at disk power-on lifetime: 51281 hours (2136 days + 17 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 04 61 00 80 84 00 40 Device Fault; Error: ABRT at LBA = 0x00008480 = 33920 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- ca 00 00 80 84 00 40 08 1d+17:25:35.144 WRITE DMA ca 00 00 80 84 00 40 08 1d+17:25:35.142 WRITE DMA ca 00 00 80 84 00 40 08 1d+17:25:35.139 WRITE DMA ca 00 00 80 84 00 40 08 1d+17:25:35.136 WRITE DMA Error 131 occurred at disk power-on lifetime: 51281 hours (2136 days + 17 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 04 61 00 80 84 00 40 Device Fault; Error: ABRT at LBA = 0x00008480 = 33920 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- ca 00 00 80 84 00 40 08 1d+17:25:35.142 WRITE DMA ca 00 00 80 84 00 40 08 1d+17:25:35.139 WRITE DMA ca 00 00 80 84 00 40 08 1d+17:25:35.136 WRITE DMA Error 130 occurred at disk power-on lifetime: 51281 hours (2136 days + 17 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 04 61 00 80 84 00 40 Device Fault; Error: ABRT at LBA = 0x00008480 = 33920 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- ca 00 00 80 84 00 40 08 1d+17:25:35.139 WRITE DMA ca 00 00 80 84 00 40 08 1d+17:25:35.136 WRITE DMA Error 129 occurred at disk power-on lifetime: 51281 hours (2136 days + 17 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 04 61 00 80 84 00 40 Device Fault; Error: ABRT at LBA = 0x00008480 = 33920 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- ca 00 00 80 84 00 40 08 1d+17:25:35.136 WRITE DMA SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Extended offline Completed without error 00% 52407 - # 2 Short offline Completed without error 00% 52327 - # 3 Short offline Completed without error 00% 52160 - # 4 Extended offline Completed without error 00% 52072 - # 5 Short offline Completed without error 00% 51992 - # 6 Short offline Completed without error 00% 51873 - # 7 Extended offline Completed without error 00% 51737 - # 8 Short offline Completed without error 00% 51657 - # 9 Short offline Completed without error 00% 51489 - #10 Extended offline Completed without error 00% 51401 - #11 Short offline Completed without error 00% 51321 - #12 Extended offline Completed without error 00% 51301 - #13 Short offline Completed without error 00% 47300 - #14 Short offline Completed without error 00% 47060 - #15 Short offline Completed without error 00% 46820 - #16 Short offline Completed without error 00% 46796 - #17 Short offline Completed without error 00% 46557 - #18 Short offline Completed without error 00% 46317 - #19 Short offline Completed without error 00% 46077 - #20 Short offline Completed without error 00% 45936 - #21 Short offline Completed without error 00% 45696 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay.
