I just had the same thing happen to me, FreeNAS-11.0-U2 and if I delete/add a volume the SMB service stops working. I can restart the service but it keeps dying off. I reboot the server, works fine as long as I am not deleting/adding volumes. I don't know if it makes a difference, but the volumes I was deleting and adding were both encrypted and had a password.
Here is the log.smbd from it crashing, me starting the service and it crashing again. As I said, once I rebooted the system seems fine and until this issue is resolved I will just plan on rebooting the server if I need to make any make any changes to the drives.
[2017/07/29 11:16:31.176338, 0] ../lib/util/fault.c:79(fault_report)
INTERNAL ERROR: Signal 11 in pid 48316 (4.6.4-GIT-5fe3bc2)
Please read the Trouble-Shooting section of the Samba HOWTO
[2017/07/29 11:16:31.176373, 0] ../lib/util/fault.c:81(fault_report)
[2017/07/29 11:16:31.176400, 0] ../source3/lib/util.c:791(smb_panic_s3)
PANIC (pid 48316): internal error
[2017/07/29 11:16:31.188545, 0] ../source3/lib/util.c:902(log_stack_trace)
BACKTRACE: 7 stack frames:
#0 0x803262d1e <log_stack_trace+0x1e> at /usr/local/lib/libsmbconf.so.0
#1 0x803262b18 <smb_panic_s3+0x98> at /usr/local/lib/libsmbconf.so.0
#2 0x800c9a597 <smb_panic+0x27> at /usr/local/lib/libsamba-util.so.0
#3 0x800c9ab40 <string_sub_once> at /usr/local/lib/libsamba-util.so.0
#4 0x800c9a563 <fault_setup+0x73> at /usr/local/lib/libsamba-util.so.0
#5 0x8008488b6 <pthread_sigmask+0x4f6> at /lib/libthr.so.3
#6 0x800847e9f <pthread_getspecific+0xe5f> at /lib/libthr.so.3
[2017/07/29 11:16:31.188666, 0] ../source3/lib/util.c:803(smb_panic_s3)
smb_panic(): calling panic action [/usr/local/libexec/samba/samba-backtrace]
ptrace: Device busy.
[2017/07/29 12:26:47.961599, 1] ../source3/profile/profile_dummy.c:30(set_profile_level)
INFO: Profiling support unavailable in this build.
[2017/07/29 12:26:48.120849, 1] ../source3/smbd/files.c:218(file_init_global)
file_init_global: Information only: requested 439562 open files, 59392 are available.
[2017/07/29 12:26:48.158205, 0] ../lib/util/become_daemon.c:124(daemon_ready)
STATUS=daemon 'smbd' finished starting up and ready to serve connections
[2017/07/29 12:26:50.390784, 1] ../source3/printing/printer_list.c:234(printer_list_get_last_refresh)
Failed to fetch record!
[2017/07/29 12:26:50.390837, 1] ../source3/smbd/server_reload.c:69(delete_and_reload_printers)
pcap cache not loaded
[2017/07/29 12:26:50.397850, 0] ../source3/smbd/trans2.c:3422(smbd_do_qfsinfo)
smbd_do_qfsinfo: not an allowed info level (0x3ef) on IPC$.
[2017/07/29 12:26:50.398059, 0] ../source3/smbd/trans2.c:3422(smbd_do_qfsinfo)
smbd_do_qfsinfo: not an allowed info level (0x105) on IPC$.
[2017/07/29 12:27:00.360853, 1] ../source3/printing/printer_list.c:234(printer_list_get_last_refresh)
[2017/07/29 12:27:00.360925, 1] ../source3/smbd/server_reload.c:69(delete_and_reload_printers)
[2017/07/29 12:27:00.361581, 0] ../source3/smbd/trans2.c:3422(smbd_do_qfsinfo)
[2017/07/29 12:27:00.361796, 0] ../source3/smbd/trans2.c:3422(smbd_do_qfsinfo)
[2017/07/29 12:27:10.366310, 1] ../source3/printing/printer_list.c:234(printer_list_get_last_refresh)
[2017/07/29 12:27:10.366375, 1] ../source3/smbd/server_reload.c:69(delete_and_reload_printers)
[2017/07/29 12:27:10.366882, 0] ../source3/smbd/trans2.c:3422(smbd_do_qfsinfo)
[2017/07/29 12:27:10.367047, 0] ../source3/smbd/trans2.c:3422(smbd_do_qfsinfo)
[2017/07/29 12:27:13.899933, 0] ../lib/util/fault.c:78(fault_report)
[2017/07/29 12:27:13.900017, 0] ../lib/util/fault.c:79(fault_report)
INTERNAL ERROR: Signal 11 in pid 96675 (4.6.4-GIT-5fe3bc2)
[2017/07/29 12:27:13.900045, 0] ../lib/util/fault.c:81(fault_report)
[2017/07/29 12:27:13.900064, 0] ../source3/lib/util.c:791(smb_panic_s3)
PANIC (pid 96675): internal error
[2017/07/29 12:27:13.900792, 0] ../source3/lib/util.c:902(log_stack_trace)
[2017/07/29 12:27:13.900893, 0] ../source3/lib/util.c:803(smb_panic_s3)
[2017/07/29 13:11:05.332882, 1] ../source3/profile/profile_dummy.c:30(set_profile_level)
[2017/07/29 13:11:05.532997, 1] ../source3/smbd/files.c:218(file_init_global)
[2017/07/29 13:11:05.626845, 0] ../lib/util/become_daemon.c:124(daemon_ready)
[2017/07/29 13:12:44.709504, 1] ../source3/profile/profile_dummy.c:30(set_profile_level)
[2017/07/29 13:12:44.721011, 1] ../source3/smbd/files.c:218(file_init_global)
[2017/07/29 13:12:44.724106, 0] ../lib/util/become_daemon.c:124(daemon_ready)
[2017/07/29 13:13:08.151334, 1] ../source3/profile/profile_dummy.c:30(set_profile_level)
[2017/07/29 13:13:08.162858, 1] ../source3/smbd/files.c:218(file_init_global)
[2017/07/29 13:13:08.165893, 0] ../lib/util/become_daemon.c:124(daemon_ready)
[2017/07/29 13:32:35.060653, 1] ../source3/profile/profile_dummy.c:30(set_profile_level)
[2017/07/29 13:32:35.190572, 1] ../source3/smbd/files.c:218(file_init_global)
[2017/07/29 13:32:35.308460, 0] ../lib/util/become_daemon.c:124(daemon_ready)
[2017/07/29 13:37:13.271865, 1] ../source3/printing/printer_list.c:234(printer_list_get_last_refresh)
[2017/07/29 13:37:13.271872, 1] ../source3/printing/printer_list.c:234(printer_list_get_last_refresh)
[2017/07/29 13:37:13.272057, 1] ../source3/smbd/server_reload.c:69(delete_and_reload_printers)
[2017/07/29 13:37:13.272064, 1] ../source3/smbd/server_reload.c:69(delete_and_reload_printers)
[2017/07/29 13:37:13.291926, 0] ../source3/smbd/trans2.c:3422(smbd_do_qfsinfo)
[2017/07/29 13:37:13.299017, 0] ../source3/smbd/trans2.c:3422(smbd_do_qfsinfo)
[2017/07/29 13:37:22.347405, 1] ../source3/printing/printer_list.c:234(printer_list_get_last_refresh)
[2017/07/29 13:37:22.347559, 1] ../source3/smbd/server_reload.c:69(delete_and_reload_printers)
[2017/07/29 13:37:22.348119, 0] ../source3/smbd/trans2.c:3422(smbd_do_qfsinfo)
[2017/07/29 13:37:22.348309, 0] ../source3/smbd/trans2.c:3422(smbd_do_qfsinfo)
[2017/07/29 13:37:32.364491, 1] ../source3/printing/printer_list.c:234(printer_list_get_last_refresh)
[2017/07/29 13:37:32.364711, 1] ../source3/smbd/server_reload.c:69(delete_and_reload_printers)
[2017/07/29 13:37:32.371821, 0] ../source3/smbd/trans2.c:3422(smbd_do_qfsinfo)
[2017/07/29 13:37:32.372039, 0] ../source3/smbd/trans2.c:3422(smbd_do_qfsinfo)
[2017/07/29 13:52:10.188574, 1] ../source3/printing/printer_list.c:234(printer_list_get_last_refresh)
[2017/07/29 13:52:10.188733, 1] ../source3/smbd/server_reload.c:69(delete_and_reload_printers)
[2017/07/29 13:52:10.312217, 1] ../source3/smbd/service.c:502(make_connection_snum)
create_connection_session_info failed: NT_STATUS_ACCESS_DENIED
[2017/07/29 13:52:10.317498, 1] ../source3/smbd/service.c:502(make_connection_snum)
