Hello
I notice some problem on 21.06 version, not present in 21.04. Currently, my NAS is connected by one Interface to router (SMB share)(1Gb), and secondly to PC (ISCS block share)(2.5Gb) (Only Ipv4 addreses, Realtek network cards.). When I restart the NAS, the static IP for direct PC connection is reseting to IPv6 version, forgetting IPv4 addres. The router connected interface is ok, as expected. The only way to set it correct is by console using ifconfig. Does anyone know the solution for the problem? Setting manual addres in GUI not work, as after test everything resets to default for direct PC interface.
Best regards
Best regards
