rslocalhost
Member
- Jan 1, 2018
Freenas 9.10-U6. In the advanced dataset options are two fields - "Quota for this dataset and all children" and "Quota for this dataset"? What's the difference?
If you quota a dataset (call it Junk, with a quota 500GiB) and then create a dataset under it (lets call that Trash), wouldn't the max space Trash could use be 500GiB minus whatever else Junk is using? Or does Trash get a separate quota (not set here, so unlimited)?
