Keven
- Aug 10, 2016
hi, i was running 11.2-U6 without problem on my pool and today i decide to upgrade to 11.2-U8 then 11.3-U2 after rebooting i noticed that i have now a critical notification saying
i looked at my pool and it report healthy.
i have run a
it says that the the overall health test result : passed
but it still show current pending sector 1 and i still have the notification. is it a sign that my drive is about to die or it can be related with the upgrade of freenas or something else?
Device: /dev/ada0, 1 Currently unreadable (pending) sectors, Thu, 9 Apr 2020 07:28:54 PM
i have run a
smartctl -a /dev/ada0
smartctl 7.0 2018-12-30 r4883 [FreeBSD 11.3-RELEASE-p7 amd64] (local build)
Copyright (C) 2002-18, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family: Western Digital Red
Device Model: WDC WD40EFRX-68WT0N0
Serial Number: WD-WCC4E0XJ74LJ
LU WWN Device Id: 5 0014ee 20d65717f
Firmware Version: 82.00A82
User Capacity: 4,000,787,030,016 bytes [4.00 TB]
Rotation Rate: 5400 rpm
ATA Version is: ACS-2 (minor revision not indicated)
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Thu Apr 9 23:14:07 2020 EDT
SMART support is: Enabled
General SMART Values:
was never started.
been run.
data collection: (52680) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 527) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x703d) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 377
3 Spin_Up_Time 0x0027 177 177 021 Pre-fail Always - 8125
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 107
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 057 057 000 Old_age Always - 31426
10 Spin_Retry_Count 0x0032 100 100 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 100 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 106
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 55
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 535
194 Temperature_Celsius 0x0022 121 109 000 Old_age Always - 31
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 1
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 100 253 000 Old_age Offline - 0
SMART Error Log Version: 1
No Errors Logged
No self-tests have been logged. [To run self-tests, use: smartctl -t]
1 0 0 Not_testing
2 0 0 Not_testingit says that the the overall health test result : passed
