aleatorvb
- Nov 14, 2012
Delock PCI Card > 2 x SATA, 1 x IDE, Code Delock 70146
Link: http://www.delock.com/produkte/G_70146/merkmale.html?setLanguage=en
How to use:
Step 1: Plug into pc
Step 2: Plug in drives
Step 3: done!
Works out of the box
Chipset
VIA VT6421A | 1043CD
How to use:
Step 3: done!
Description
The Delock Controller card has to be plugged internal to the PCI slot. You can connect hard disks, CD-ROM drives or other devices to the controller card. Due to the Raid function you can connect multiple hard disks logical and raise the data security, the speed or capacity.
Specification
• 2x SATA I specification
• 1x PATA IDE specification
• Data transfer rate: SATA up to 1.5 Gbps
PATA up to 133 Mbps
• 32-Bit PCI standard 2.2
• Supports up to 2 HDDs on the SATA controller as well as 2 HDDs on the IDE controller
• Supports Hard disks more than 137 GB
• Raid 0, 1, 0+1, JBOD
System requirements
• PC with one free PCI Slot
• Windows 2000/winXP/Server 2003/Vista, Linux od Kernel 2.6
Package content
• Controller card
• Driver CD
• User manual
Package
• Blister
Chipset
