I have acquired a dell r710, replaced the perc6i with a cross flashed h310 to it firmware. I have searched the forums for similar configurations and have found others have had similar issues but with no resolution. If I leave the dell 6gpbsas firmware on the card, all 6 wd re3 drives installed in the backplane show in the bios. If I flash the card to 9211-8i firmware P7 all is well. I can flash the card up to P16 and works ok. With P17 or later the drives will not show in the bios or other software. During trial and error, I flashed p7->p10->p15->p16 all worked. If i add drives to a breakout cable with P17 or later all drives are seen, but not when connected to the backplane. Downgraded the card to P16 and all is well again. Has anyone else had these peculiar issues with a R710?
EDIT: a little more info / update
My drives are WD RE3 - WD1002FBYS-05A6B0. None are detected. I replaced one in the backplane with a WD Black WD1003FZEX that I had lying around. It it detected as a 1TB 6gbp drive as it should. The RE3 drives detect in another machine(on board sata) as 1TB, link speed only at 1.5gb although the drives and motherboard are capable of at least 3gb.
Thanks
Thanks
