SOLVED Issues with a crossflashed Dell h310
electronicks
So I've been playing around with FreeNAS for the last few days and I'm struggling to get one issue fixed. I flashed a dell h310 into IT mode using this guide (https://techmattr.wordpress.com/201...-flashing-to-it-mode-dell-perc-h200-and-h310/) and I haven't been able to get it to recognize all of my disks. For some reason the system only sees one connected to my backplane. I'm using this case (https://www.amazon.com/Rosewill-Rackmount-Computer-Pre-Installed-RSV-L4000/dp/B00N9CXGSO?th=1). I've had 4 total connected and it for some reason will only see one. I first tried with the p20 then later p16 version of the LSI software and it didnt seem to make a difference. I'm using drives larger then 2tb if that makes a difference? Because my motherboard is a bit older, I'm using FreeNAS version 9.3.1 stable.
electronicks
I ended up discovering the issue after moving all the disks around. My backplane was not getting power correctly and a few of the slots weren't able to fully power 3.5" disks but could power my ssd. All disks are now accounted for. I also updated my card back to p20 and updated through the gui to 9.10.
