so i had some plugins fail to install. when i try to go to the plugins section of the GUI to delete them, the error below shows up. when i try to delete the plugin jail via the GUI's jail section, there's nothing listed. when i try to delete the plugin directory via CLI under the iocage directory, i receive "Device busy" message. Is there a clean way to remove a failed plugin install?
Error: concurrent.futures.process._RemoteTraceback: """ Traceback (most recent call last): File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_json.py", line 244, in json_load jail_dataset.properties["org.freebsd.iocage:host_hostuuid"] File "libzfs.pyx", line 2059, in libzfs.ZFSPropertyDict.__getitem__ KeyError: 'org.freebsd.iocage:host_hostuuid' During handling of the above exception, another exception occurred: Traceback (most recent call last): File "/usr/local/lib/python3.6/concurrent/futures/process.py", line 175, in _process_worker r = call_item.fn(*call_item.args, **call_item.kwargs) File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 122, in main_worker res = loop.run_until_complete(coro) File "/usr/local/lib/python3.6/asyncio/base_events.py", line 468, in run_until_complete return future.result() File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 82, in _run return await self._call(f'{service_name}.{method}', serviceobj, methodobj, params=args, job=job) File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 75, in _call return methodobj(*params) File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 75, in _call return methodobj(*params) File "/usr/local/lib/python3.6/site-packages/middlewared/schema.py", line 668, in nf return f(*args, **kwargs) File "/usr/local/lib/python3.6/site-packages/middlewared/plugins/jail.py", line 462, in list_resource resource_list = iocage.list("all", plugin=True) File "/usr/local/lib/python3.6/site-packages/iocage_lib/iocage.py", line 1150, in list quick=quick File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_list.py", line 75, in list_datasets _all = self.list_all(ds) File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_list.py", line 153, in list_all conf = iocage_lib.ioc_json.IOCJson(mountpoint).json_load() File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_json.py", line 259, in json_load silent=self.silent) File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_common.py", line 81, in logit _callback(content, exception) File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_common.py", line 64, in callback raise callback_exception(message) RuntimeError: transmission_2 is missing it's configuration, please destroy this jail and recreate it. """ The above exception was the direct cause of the following exception: Traceback (most recent call last): File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 161, in call_method result = await self.middleware.call_method(self, message) File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1043, in call_method return await self._call(message['method'], serviceobj, methodobj, params, app=app, io_thread=False) File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 980, in _call return await self._call_worker(serviceobj, name, *args) File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1007, in _call_worker job, File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 938, in run_in_proc return await self.run_in_executor(self.__procpool, method, *args, **kwargs) File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 923, in run_in_executor return await loop.run_in_executor(pool, functools.partial(method, *args, **kwargs)) RuntimeError: transmission_2 is missing it's configuration, please destroy this jail and recreate it.
