I have been spending a considerable time with the Freenas Mini .. But things are mostly working after a boot device fail, except the following issue:
Yes, I have tried to online it, was looking at replacing it when I found what I *think* the problem, is some of the device labels have disappeared.
gpart lists the device and all its partitions, , the device has passed the short SMART test I have run..
After running glable status, I find that its missing a few of == gpart devices.
Bottom line, the was /dev/gptid/13cd0d02-d642-11e7-8936-d05099c311bd bit is missing from
So, I am pretty sure I just need to re-add the missing labels .. but I am not sure I know the correct command to use so that it will re-join the pool successfully. I suspect restoring all the missing devices labels might be needed, however, I only know what this one devices label should be.
Thanks for any suggestions..
pool: main state: DEGRADED status: One or more devices has been taken offline by the administrator. Sufficient replicas exist for the pool to continue functioning in a degraded state. action: Online the device using 'zpool online' or replace the device with 'zpool replace'. scan: scrub repaired 0 in 0 days 01:31:09 with 0 errors on Sun May 19 01:31:10 2019 config: NAME STATE READ WRITE CKSUM main DEGRADED 0 0 0 mirror-0 DEGRADED 0 0 0 14361325566141919790 OFFLINE 0 0 0 was /dev/gptid/13cd0d02-d642-11e7-8936-d05099c311bd gptid/14f630b6-d642-11e7-8936-d05099c311bd ONLINE 0 0 0 mirror-1 ONLINE 0 0 0 gptid/161d45a1-d642-11e7-8936-d05099c311bd ONLINE 0 0 0 gptid/1743ac36-d642-11e7-8936-d05099c311bd ONLINE 0 0 0
glabel status Name Status Components gptid/ab294291-d2a2-11e9-905e-d05099c311bd N/A ada0p1 gptid/ab2c3d07-d2a2-11e9-905e-d05099c311bd N/A ada0p2 gptid/4cef39f6-8d75-11e9-b12f-d05099c311bd N/A ada1p1 gptid/14f630b6-d642-11e7-8936-d05099c311bd N/A ada2p2 gptid/161d45a1-d642-11e7-8936-d05099c311bd N/A ada3p2 gptid/1743ac36-d642-11e7-8936-d05099c311bd N/A ada4p2 gptid/14dfe5da-d642-11e7-8936-d05099c311bd N/A ada2p1
