Apologies if this is a simple question but I need some help in identify if there is a problem with my pool and whether is requires a HDD replacement.
My pool is currently in a DEGRADED state, I have 4 (6TB) disks in my pool with 2 disk redundancy. When looking at the status one of the disks (da5p2) is in a DEGRADED state (Checksum 280?).
I've ran this command: smartctl -q noserial -a /dev/da5
Results below:
Results below:
smartctl 6.5 2016-05-07 r4318 [FreeBSD 11.0-STABLE amd64] (local build) Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Western Digital Red Device Model: WDC WD60EFRX-68MYMN1 Firmware Version: 82.00A82 User Capacity: 6,001,175,126,016 bytes [6.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 5700 rpm Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-2, ACS-3 T13/2161-D revision 3b SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Wed Feb 21 14:13:30 2018 GMT SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x00) Offline data collection activity was never started. Auto Offline Data Collection: Disabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: ( 2984) seconds. Offline data collection capabilities: (0x7b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 684) minutes. Conveyance self-test routine recommended polling time: ( 5) minutes. SCT capabilities: (0x303d) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0 3 Spin_Up_Time 0x0027 195 185 021 Pre-fail Always - 9241 4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 80 5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0 7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0 9 Power_On_Hours 0x0032 064 064 000 Old_age Always - 26321 10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0 11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 78 192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 63 193 Load_Cycle_Count 0x0032 197 197 000 Old_age Always - 10660 194 Temperature_Celsius 0x0022 118 107 000 Old_age Always - 34 196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0 197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0 200 Multi_Zone_Error_Rate 0x0008 100 253 000 Old_age Offline - 0 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Short offline Completed without error 00% 26319 - # 2 Short offline Completed without error 00% 26307 - # 3 Short offline Completed without error 00% 26295 - # 4 Short offline Completed without error 00% 26283 - # 5 Short offline Completed without error 00% 26271 - # 6 Short offline Completed without error 00% 26259 - # 7 Short offline Completed without error 00% 26247 - # 8 Short offline Completed without error 00% 26235 - # 9 Short offline Completed without error 00% 26223 - #10 Short offline Completed without error 00% 26211 - #11 Short offline Completed without error 00% 26199 - #12 Short offline Completed without error 00% 26187 - #13 Short offline Completed without error 00% 26175 - #14 Short offline Completed without error 00% 26173 - #15 Short offline Completed without error 00% 26163 - #16 Short offline Completed without error 00% 26151 - #17 Short offline Completed without error 00% 26139 - #18 Short offline Completed without error 00% 26127 - #19 Short offline Completed without error 00% 26115 - #20 Short offline Completed without error 00% 26103 - #21 Short offline Completed without error 00% 26091 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay.
