Degraded status and cant log in
RadarG
I received an email from freenas saying that my zfs pool was degraded I went to logon and found this http://imgur.com/PBj97dY
I received this via email.
Checking status of zfs pools: NAME SIZE ALLOC FREE CAP DEDUP HEALTH ALTROOT pictures 2.25T 1.53T 737G 68% 1.00x DEGRADED /mnt
pool: pictures state: DEGRADED status: One or more devices are faulted in response to persistent errors. Sufficient replicas exist for the pool to continue functioning in a degraded state. action: Replace the faulted device, or use 'zpool clear' to mark the device repaired. scan: scrub repaired 0 in 2h8m with 0 errors on Sun Nov 23 02:08:27 2014 config:
NAME STATE READ WRITE CKSUM
pictures DEGRADED 0 0 0
raidz3-0 DEGRADED 0 0 0
gptid/f2dc157e-152d-11e4-b51d-bc305bcfb8a8 ONLINE 0 0 0
gptid/f447bef7-152d-11e4-b51d-bc305bcfb8a8 ONLINE 0 0 0
gptid/f516e873-152d-11e4-b51d-bc305bcfb8a8 FAULTED 0 132 0 too many errors
gptid/f579d907-152d-11e4-b51d-bc305bcfb8a8 ONLINE 0 0 0
gptid/f5fc7a2c-152d-11e4-b51d-bc305bcfb8a8 ONLINE 0 0 0
errors: No known data errors
-- End of daily output --
Please help I know I have to go over to the console but what do I do?
RadarG
When I walk over to the console. I would normally see the interface listed that is used by the web console. In my case it was bge0 192.168.1.186 it's blank not. Do I reboot and see if I can get into the web console.
diedrichg
You have a bad disk and you have five disks so I'm guessing your pool is raidz1? If that's the case then I suggest you shut down immediately until you can get some additional help here on the forums to identify exactly which disk it is. ...Because, if you lose another disk then you will lose your data because the pool is Z1. Clearly it's the "gptid/f516e873...b8a8" disk.
RadarG
I looked through my emails and found that the drive in question mfisyspd3 but how do I know what drive to physically pull.
And guess what!? We don't either since you are clearly using RAID with ZFS (which is a big no-no). mfisyspd(X) = RAID
RadarG
ok I dont understand. I have the drives running through a IBM M1015 ServeRaid SAS/SATA PCI-e RAID Controller LSI SAS9220-8i 46M0861 which to my understanding is the preferred card for freenas. Please explain how this is a no no.
BigDave
FreeNAS Enthusiast
ZFS needs direct access to your drives, i.e. HBA in IT mode.
This thread will help I think;)
no_connection
Just don't change mode on the RAID controller with data on the disks as this usually destroys the data.
