Stux
- Jun 2, 2016
One for every four drives? That's just an electrical connection, with no logic, which is fine (since you have the separate expander).
That's the one, if your Intel SAS Expander is a 24 port, then you should be able to run one of the SFF-8087 cables from the HBA to it, and 5 from the expander to 5 of the Norco backplanes, and then the final SFF-8087 cable from the other HBA port to the last backplane.
I've actually just ordered an Intel 36 port SAS expander for my Norco 4224, so that should be fun when it arrives. I *should* be able to use dual-link and connect all 24 bays, and 4 additional SSDs connected up to a single HBA.
Booting through the expander is apparently tricky though.
Still, that leaves 10 sata ports on the motherboard...
