Hi everybody
I've got the alert for the first time a few days ago that my pool is degraded due to 15 read errors on one of the drives (see picture below). I've completed a long S.M.A.R.T. test and did a scrub since which did not resolve it. The hardware of my PC is in my signature.
Output for smartctl -a /dev/sdf
Output for zpool status -v
While the the S.M.A.R.T. tests don't show anything remarkable (as far as i can tell) and the pool status sais "no known data errors" I'm at a loss to what the problem is. What do I need to do to clear the degraded status?
If of importance: a few days prior to the error showing up i shut down the system via webinterface, opened the case up and cleaned it and the airfilters with canned air.
root@truenas[~]# smartctl -a /dev/sdf smartctl 7.2 2020-12-30 r5155 [x86_64-linux-5.15.131+truenas] (local build) Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Device Model: WDC WD80EFZZ-68BTXN0 Serial Number: WD-CA2L12BK LU WWN Device Id: 5 0014ee 2c0438d9b Firmware Version: 81.00A81 User Capacity: 8,001,563,222,016 bytes [8.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 5640 rpm Form Factor: 3.5 inches Device is: Not in smartctl database [for details use: -P showall] ATA Version is: ACS-3 T13/2161-D revision 5 SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Tue Nov 7 11:29:48 2023 CET SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x00) Offline data collection activity was never started. Auto Offline Data Collection: Disabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: (18164) seconds. Offline data collection capabilities: (0x11) SMART execute Offline immediate. No Auto Offline data collection support. Suspend Offline collection upon new command. No Offline surface scan supported. Self-test supported. No Conveyance Self-test supported. No Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 884) minutes. SCT capabilities: (0x303d) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0 3 Spin_Up_Time 0x0027 188 188 021 Pre-fail Always - 9566 4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 20 5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0 7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0 9 Power_On_Hours 0x0032 093 093 000 Old_age Always - 5496 10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0 11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 11 192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 7 193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 28 194 Temperature_Celsius 0x0022 119 097 000 Old_age Always - 33 196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0 197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0 200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Extended offline Completed without error 00% 5488 - # 2 Short offline Completed without error 00% 5413 - # 3 Short offline Completed without error 00% 5365 - # 4 Short offline Completed without error 00% 5317 - # 5 Short offline Completed without error 00% 5244 - # 6 Short offline Completed without error 00% 5196 - # 7 Short offline Completed without error 00% 5148 - # 8 Short offline Completed without error 00% 5076 - # 9 Short offline Completed without error 00% 5028 - #10 Short offline Completed without error 00% 4980 - #11 Short offline Completed without error 00% 4908 - #12 Short offline Completed without error 00% 4860 - #13 Short offline Completed without error 00% 4812 - #14 Short offline Completed without error 00% 4740 - #15 Short offline Completed without error 00% 4693 - #16 Short offline Completed without error 00% 4645 - #17 Short offline Completed without error 00% 4573 - #18 Short offline Completed without error 00% 4525 - #19 Extended offline Completed without error 00% 4480 - #20 Short offline Completed without error 00% 4405 - #21 Short offline Completed without error 00% 4357 - Selective Self-tests/Logging not supported
root@truenas[~]# zpool status -v pool: boot-pool state: ONLINE status: Some supported and requested features are not enabled on the pool. The pool can still be used, but some features are unavailable. action: Enable all features using 'zpool upgrade'. Once this is done, the pool may no longer be accessible by software that does not support the features. See zpool-features(7) for details. scan: scrub repaired 0B in 00:02:01 with 0 errors on Wed Nov 1 03:47:02 2023 config: NAME STATE READ WRITE CKSUM boot-pool ONLINE 0 0 0 sda3 ONLINE 0 0 0 errors: No known data errors pool: storage0 state: DEGRADED status: One or more devices are faulted in response to persistent errors. Sufficient replicas exist for the pool to continue functioning in a degraded state. action: Replace the faulted device, or use 'zpool clear' to mark the device repaired. scan: scrub repaired 0B in 05:30:34 with 0 errors on Tue Nov 7 03:15:10 2023 config: NAME STATE READ WRITE CKSUM storage0 DEGRADED 0 0 0 raidz2-0 DEGRADED 0 0 0 2efc6d96-3c27-490c-953b-9b205f81e679 FAULTED 15 0 0 too many errors e406c91a-5d0e-407d-8ec2-c7b9d4ee4025 ONLINE 0 0 0 c620bc69-66c3-4589-8e9b-a375bc3ea9c5 ONLINE 0 0 0 ab75c80d-f093-42f5-81d1-2c68ecd07428 ONLINE 0 0 0 aa729717-a79c-4e9a-b47c-7a08c2b00f6b ONLINE 0 0 0 errors: No known data errors
