Dear all,
I'm running TrueNAS-SCALE-22.02-RC.2 with a single pool:
(disks 4T disks are new ones, 3T disks are my own used in previous NAS)
After initial set-up I executed some SMART tests but one of my older disks failed to pass.
I tried to investigate, manually executed LONG and SELECT tests, still the same result.
I wanted to follow this post for further investigation/resolving, however this applies to ext2/ext3 only.
I assume that errors in the Attributes section (Raw_Read_Error_Rate and Multi_Zone_Error_Rate) which are actually related to this issue are not critical ones (are they?).
But now I'd like to know how to resolve the issue in order to stop failing the regular SMART tests.
Thanks for any help in advance...
root@truenas[~]# zpool list -v
NAME SIZE ALLOC FREE CKPOINT EXPANDSZ FRAG CAP DEDUP HEALTH ALTROOT
DataPool 6.34T 2.34T 4.01T - - 0% 36% 1.00x ONLINE /mnt
mirror 3.62T 2.34T 1.29T - - 0% 64.4% - ONLINE
038179d3-ce48-4f9a-a34f-d4c1073c5ba2 - - - - - - - - ONLINE
db3a4457-ccef-408b-a401-131b31278967 - - - - - - - - ONLINE
mirror 2.72T 1.21G 2.72T - - 0% 0.04% - ONLINE
76db0406-4dbe-443c-99c3-dbd2ea34f2de - - - - - - - - ONLINE
11d527de-af45-491c-944e-298ad05d755b - - - - - - - - ONLINE
boot-pool 13.5G 2.98G 10.5G - - 3% 22% 1.00x ONLINE -
sde3 13.5G 2.98G 10.5G - - 3% 22.0% - ONLINEAfter initial set-up I executed some SMART tests but one of my older disks failed to pass.
Model Family: Western Digital Red
Device Model: WDC WD30EFRX-68EUZN0
Serial Number: WD-WCC4N5FPESPZ
LU WWN Device Id: 5 0014ee 2b840be71
Firmware Version: 82.00A82
User Capacity: 3,000,592,982,016 bytes [3.00 TB]
Rotation Rate: 5400 rpm
ATA Version is: ACS-2 (minor revision not indicated)
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Sun Jan 16 10:01:39 2022 CET
SMART support is: Enabled
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
Self-test execution status: ( 121) The previous self-test completed having
the read element of the test failed.
data collection: (38460) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 386) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x703d) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 1
3 Spin_Up_Time 0x0027 193 178 021 Pre-fail Always - 5316
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 201
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 039 039 000 Old_age Always - 44786
10 Spin_Retry_Count 0x0032 100 100 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 100 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 201
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 164
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 532
194 Temperature_Celsius 0x0022 117 107 000 Old_age Always - 33
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 200 200 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 5
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 1
SMART Error Log Version: 1
No Errors Logged
# 1 Selective offline Completed: read failure 90% 44786 409252712
# 2 Extended offline Completed: read failure 90% 44763 409252712
# 3 Short offline Completed: read failure 10% 44755 409252712
# 4 Short offline Completed without error 00% 44710 -
# 5 Short offline Completed without error 00% 44686 -
# 6 Short offline Completed without error 00% 44662 -
# 7 Short offline Completed without error 00% 44638 -
# 8 Extended offline Completed without error 00% 44621 -
# 9 Short offline Completed without error 00% 44590 -
#10 Short offline Completed without error 00% 44566 -
#11 Short offline Completed without error 00% 44542 -
#12 Short offline Completed without error 00% 44518 -
#13 Short offline Completed without error 00% 44494 -
#14 Short offline Completed without error 00% 44470 -
#15 Extended offline Completed without error 00% 44453 -
#16 Short offline Completed without error 00% 44422 -
#17 Short offline Completed without error 00% 44398 -
#18 Short offline Completed without error 00% 44374 -
#19 Short offline Completed without error 00% 44350 -
#20 Short offline Completed without error 00% 44326 -
#21 Short offline Completed without error 00% 44302 -
1 409252712 409252713 Completed_read_failure [90% left] (409252712-409318247)
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
If Selective self-test is pending on power-up, resume after 0 minute delay.But now I'd like to know how to resolve the issue in order to stop failing the regular SMART tests.
