I've gotten down to 2 file errors although I'm not sure if that's because of the scrubs/resilver or because I've been purging. As long as I was spending all this time on maintenance I updated to 11.1 but of course that had no effect. I switched to AHCI and still seeing the errors.
I suppose it could be a power supply issue but then I would expect different error counts on each of drives and memtest86 failures. I'm leaning toward a SATA controller issue.
Model Family: Western Digital Red
Device Model: WDC WD30EFRX-68AX9N0
Serial Number: WD-WCC1T0901015
LU WWN Device Id: 5 0014ee 2b3162f5d
Firmware Version: 80.00A80
User Capacity: 3,000,592,982,016 bytes [3.00 TB]
ATA Version is: ACS-2 (minor revision not indicated)
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Tue Jan 16 00:00:00 2018 IST
SMART support is: Enabled
General SMART Values:
was never started.
been run.
data collection: (39120) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 393) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x70bd) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 188 182 021 Pre-fail Always - 5591
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 399
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 054 054 000 Old_age Always - 34277
10 Spin_Retry_Count 0x0032 100 100 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 100 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 399
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 256
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 142
194 Temperature_Celsius 0x0022 121 105 000 Old_age Always - 29
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0
SMART Error Log Version: 1
No Errors Logged
# 1 Short offline Completed without error 00% 34200 -
# 2 Short offline Completed without error 00% 34199 -
# 3 Extended offline Interrupted (host reset) 10% 34146 -
# 4 Short offline Completed without error 00% 34069 -
# 5 Short offline Completed without error 00% 33975 -
# 6 Short offline Completed without error 00% 33855 -
# 7 Short offline Completed without error 00% 33767 -
# 8 Short offline Completed without error 00% 33648 -
# 9 Extended offline Completed without error 00% 33512 -
#10 Short offline Completed without error 00% 33458 -
#11 Short offline Completed without error 00% 33339 -
#12 Short offline Completed without error 00% 33218 -
#13 Short offline Completed without error 00% 33124 -
#14 Short offline Completed without error 00% 33123 -
#15 Short offline Completed without error 00% 33031 -
#16 Short offline Completed without error 00% 32815 -
#17 Short offline Completed without error 00% 32720 -
#18 Short offline Completed without error 00% 32484 -
#19 Short offline Completed without error 00% 32391 -
#20 Extended offline Completed without error 00% 32290 -
#21 Short offline Completed without error 00% 32144 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
smartctl 6.5 2016-05-07 r4318 [FreeBSD 11.1-STABLE amd64] (local build)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
Device Model: WDC WD30EFRX-68EUZN0
Serial Number: WD-WCC4N2NNASEZ
LU WWN Device Id: 5 0014ee 2610ef873
Firmware Version: 82.00A82
Rotation Rate: 5400 rpm
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 3.0 Gb/s)
was never started.
been run.
data collection: (40320) seconds.
command.
power-saving mode.
recommended polling time: ( 404) minutes.
SCT capabilities: (0x703d) SCT Status supported.
3 Spin_Up_Time 0x0027 197 177 021 Pre-fail Always - 5125
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 266
7 Seek_Error_Rate 0x002e 100 253 000 Old_age Always - 0
9 Power_On_Hours 0x0032 075 075 000 Old_age Always - 18716
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 260
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 141
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 1165
194 Temperature_Celsius 0x0022 122 108 000 Old_age Always - 28
No Errors Logged
# 1 Short offline Completed without error 00% 18651 -
# 2 Extended offline Completed without error 00% 18491 -
# 3 Short offline Completed without error 00% 18435 -
# 4 Short offline Completed without error 00% 18317 -
# 5 Short offline Completed without error 00% 18110 -
# 6 Short offline Completed without error 00% 18015 -
# 7 Extended offline Completed without error 00% 17855 -
# 8 Short offline Completed without error 00% 17800 -
# 9 Short offline Completed without error 00% 17681 -
#10 Short offline Completed without error 00% 17587 -
#11 Short offline Completed without error 00% 17373 -
#12 Extended offline Completed without error 00% 17213 -
#13 Short offline Completed without error 00% 17183 -
#14 Short offline Completed without error 00% 16948 -
#15 Short offline Completed without error 00% 16759 -
#16 Short offline Completed without error 00% 16608 -
#17 Short offline Completed without error 00% 16514 -
#18 Short offline Completed without error 00% 16346 -
#19 Short offline Completed without error 00% 16253 -
#20 Extended offline Completed without error 00% 16091 -
#21 Short offline Interrupted (host reset) 10% 16037 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Serial Number: WD-WCC4N3VR2R89
LU WWN Device Id: 5 0014ee 20bb9ed99
was never started.
been run.
data collection: (39900) seconds.
command.
power-saving mode.
recommended polling time: ( 400) minutes.
3 Spin_Up_Time 0x0027 202 181 021 Pre-fail Always - 4891
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 140
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 1207
194 Temperature_Celsius 0x0022 120 105 000 Old_age Always - 30
No Errors Logged
# 1 Short offline Completed without error 00% 18638 -
# 2 Short offline Completed without error 00% 18602 -
# 3 Short offline Completed without error 00% 18387 -
# 4 Extended offline Completed without error 00% 18258 -
# 5 Short offline Completed without error 00% 18182 -
# 6 Short offline Completed without error 00% 18181 -
# 7 Short offline Completed without error 00% 17967 -
# 8 Short offline Completed without error 00% 17873 -
# 9 Short offline Completed without error 00% 17872 -
#10 Short offline Completed without error 00% 17752 -
#11 Short offline Completed without error 00% 17538 -
#12 Short offline Completed without error 00% 17444 -
#13 Short offline Completed without error 00% 17229 -
#14 Short offline Completed without error 00% 17136 -
#15 Extended offline Interrupted (host reset) 80% 16995 -
#16 Short offline Completed without error 00% 16805 -
#17 Short offline Completed without error 00% 16746 -
#18 Short offline Completed without error 00% 16653 -
#19 Short offline Completed without error 00% 16559 -
#20 Extended offline Completed without error 00% 16447 -
#21 Short offline Completed without error 00% 16203 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Serial Number: WD-WCC4N4XF52T2
LU WWN Device Id: 5 0014ee 2b6638287
was never started.
been run.
data collection: (40380) seconds.
command.
power-saving mode.
recommended polling time: ( 405) minutes.
3 Spin_Up_Time 0x0027 200 179 021 Pre-fail Always - 5000
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 265
9 Power_On_Hours 0x0032 075 075 000 Old_age Always - 18717
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 1184
194 Temperature_Celsius 0x0022 123 107 000 Old_age Always - 27
No Errors Logged
# 1 Short offline Completed without error 00% 18673 -
# 2 Short offline Completed without error 00% 18555 -
# 3 Short offline Completed without error 00% 18460 -
# 4 Short offline Completed without error 00% 18342 -
# 5 Short offline Completed without error 00% 18229 -
# 6 Extended offline Interrupted (host reset) 80% 18157 -
# 7 Short offline Completed without error 00% 18039 -
# 8 Short offline Completed without error 00% 17825 -
# 9 Short offline Completed without error 00% 17705 -
#10 Short offline Completed without error 00% 17611 -
#11 Extended offline Completed without error 00% 17522 -
#12 Short offline Completed without error 00% 17397 -
#13 Short offline Completed without error 00% 17067 -
#14 Short offline Completed without error 00% 16974 -
#15 Extended offline Completed without error 00% 16909 -
#16 Short offline Completed without error 00% 16699 -
#17 Short offline Completed without error 00% 16632 -
#18 Short offline Completed without error 00% 16538 -
#19 Short offline Completed without error 00% 16420 -
#20 Extended offline Completed without error 00% 16401 -
#21 Short offline Completed without error 00% 16275 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
