atomique90
- Jul 13, 2018
Hello guys,
maybe one of you has an idea for my big problem: I encrypted my disks but cant decrypt them. I saved my geli.key but FreeNAS doesnt accept it.
What I did:
Error in the shell:
What I didn't / maybe my mistake here:
I checked the documentation and its mentioned there, that I have to disconnect and export the pool before moving to a new FreeNAS system. The problem is, that I have formatted the USB-Stick from the first FreeNAS instance. I changed to the new system, because I got some weird errors during boot that stopped after reinstalling FreeNAS onto a new SSD. Could this be a problem?
The system:
- FreeNAS 11.2 U6
- 2 Disks mirrored and encrypted
Is it possible to decrypt the pool? Is the format of my geli.key wrong maybe? I have just copied it to a file (windows notepad) - maybe thats the problem. Please let me know if you need further information.
Note: I also posted this issue on reddit, but I think its better placed in here. Please dont wonder if you see this twice!
Thank you guys for any help!
Atomique
What I did:
- Encrypted the pool
- Saved my geli.key (copied the content to my passwordsafe)
- Moved the disks to a fresh install (I dont have access to the old environment anymore)
- Tried to import it via GUI and Shell with geli.key (no passphrase, I just have this geli.key)
File "/usr/local/lib/python3.6/site-packages/middlewared/job.py", line 333, in run
await self.future
File "/usr/local/lib/python3.6/site-packages/middlewared/job.py", line 366, in __run_body
rv = await self.middleware.run_in_thread(self.method, *([self] + args))
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1004, in run_in_thread
return await self.loop.run_in_executor(executor, functools.partial(method, *args, **kwargs))
File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 56, in run
File "/usr/local/lib/python3.6/site-packages/middlewared/schema.py", line 668, in nf
return f(*args, **kwargs)
File "/usr/local/lib/python3.6/site-packages/middlewared/plugins/disk.py", line 253, in decrypt
raise CallError(f'The following devices failed to attach: {", ".join(failed)}')
middlewared.service_exception.CallError: [EFAULT] The following devices failed to attach: gptid/ae24d1a8-03b9-11ea-9421-001b21bd9510, gptid/ade387e0-03b9-11ea-9421-001b21bd9510
Error in the shell:
root@freenas[/tmp]# geli attach -p -k /tmp/geli.key /dev/gptid/ae24d1a8-03b9-11ea-9421-001b21bd9510 geli: Wrong key for gptid/ae24d1a8-03b9-11ea-9421-001b21bd9510.
The system:
- FreeNAS 11.2 U6
Atomique
