IceBoosteR
- Sep 27, 2016
Hi folks,
another time that encryption with FreeNAS drives me crazy. Try to keep long story short.
Had mirrored boot pool. I came back after some weeks and both USB thumb drives died. I could not boot the machine anymore. Could save a backup from the database though. Installed fresh 11.2-U5 and uploaded my conig from 11.1-U7 - no issue.
But I am unable to open my encrypted pools. Of course I do have the geli.key, the recovery.key and the passphrase - but no luck via GUI nor CLI.
Messages like:
I have actually NO guess how to move on. I assume my data is still there. Maybe I can recover the data from the broken thumb drives? Need to figure out on which system though. Anyhow any idea how to manually import would be AWESOME!
Thank you
Messages like:
- geli: Wrong key for da6p2
- Importing RED [1922545619372436668] failed with: cannot import '1922545619372436668': no such pool available
- geli: Cannot read metadata from /dev/da6p1: Invalid argument
File "/usr/local/lib/python3.6/site-packages/middlewared/job.py", line 332, in run
await self.future
File "/usr/local/lib/python3.6/site-packages/middlewared/job.py", line 365, in __run_body
rv = await self.middleware.run_in_thread(self.method, *([self] + args))
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1006, in run_in_thread
return await self.loop.run_in_executor(executor, functools.partial(method, *args, **kwargs))
File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 56, in run
File "/usr/local/lib/python3.6/site-packages/middlewared/schema.py", line 668, in nf
return f(*args, **kwargs)
File "/usr/local/lib/python3.6/site-packages/middlewared/plugins/disk.py", line 253, in decrypt
raise CallError(f'The following devices failed to attach: {", ".join(failed)}')
middlewared.service_exception.CallError: [EFAULT] The following devices failed to attach: gptid/50245289-8164-11e8-a571-1866da308b0d, gptid/4f4d1954-8164-11e8-a571-1866da308b0d, gptid/4e769436-8164-11e8-a571-1866da308b0d, gptid/4db11db0-8164-11e8-a571-1866da308b0d, gptid/4cf26b2f-8164-11e8-a571-1866da308b0d, gptid/4c2219f0-8164-11e8-a571-1866da308b0d, gptid/4b56f034-8164-11e8-a571-1866da308b0d, gptid/4a5608c3-8164-11e8-a571-1866da308b0d, gptid/48be4b72-8164-11e8-a571-1866da308b0d, gptid/498e87dd-8164-11e8-a571-1866da308b0d
Thank you
