Build FreeNAS-9.3-STABLE-201509022158
I'm having an issue with my Dataset after importing the volume. The problem occurs when I try changing the share type from UNIX To Windows. Here is the error message I am receiving:
Any help would be greatly appreciated. Thank you!
Environment: Software Version: FreeNAS-9.3-STABLE-201509022158 Request Method: POST Request URL: http://192.168.32.55/storage/dataset/edit/CYAS-VOLUME/backups/ Traceback: File "/usr/local/lib/python2.7/site-packages/django/core/handlers/base.py" in get_response 105. response = middleware_method(request, callback, callback_args, callback_kwargs) File "/usr/local/www/freenasUI/../freenasUI/freeadmin/middleware.py" in process_view 157. return login_required(view_func)(request, *view_args, **view_kwargs) File "/usr/local/lib/python2.7/site-packages/django/contrib/auth/decorators.py" in _wrapped_view 22. return view_func(request, *args, **kwargs) File "/usr/local/www/freenasUI/../freenasUI/storage/views.py" in dataset_edit 466. dataset_name, val) File "/usr/local/www/freenasUI/../freenasUI/middleware/notifier.py" in change_dataset_share_type 5280. self.dataset_init_windows_meta_file(dataset) File "/usr/local/www/freenasUI/../freenasUI/middleware/notifier.py" in dataset_init_windows_meta_file 5241. with open("%s/.windows" % path, "w") as f: Exception Type: IOError at /storage/dataset/edit/CYAS-VOLUME/backups/ Exception Value: [Errno 2] No such file or directory: u'/mnt/CYAS-VOLUME/backups/.windows'
