AnosVoldigoad
- Apr 4, 2021
Hello together,I have the problem that when I select any docker container from docker hub, I can configure and start it was. The problem is that as soon as I turn the container off and on again, all settings, configurations and changes in the container are gone again, as if it had been reinstalled or simply all changes are made only temporarily.
How did I proceed?
-Selected "Lounch Docker Image" under Apps.
-Set a name.
-Specified the Docker container in the image repository (from Docker Hub).
-Didn't touch most of the settings for testing purposes, almost every container should run like this. Until just a few of the required environment variables set.
-Setup completed
Docker downloads the image, installs and starts. Everything as it should.
After that I set a few things under the web interface, all so far io.
As soon as I restart the container all settings are gone and I can set everything again on the website of the container.
Tested containers:
(i guess the problem affects all containers)
I know that I can include the truecharts list, which I have already done. However, I also want to install some docker that doesn't exist in the list. That must be possible or not?
I hope someone can help me with my problem or should I wait until the next update of Truena's Scale comes out?
Translated with www.DeepL.com/Translator (free version)
How did I proceed?
-Set a name.
-Setup completed
Tested containers:
