Thomas_VDB
- Sep 22, 2012
Longtime FreeNAS-lover here.
Also sysadmin at a small business, where I'm using a Supermicro server with Freenas as SAN (iSCSI) for 2 ESXi hosts.
At home, I've been using a Microserver N40L for ages, and although it has been running rock-solid, it's time for a replacement.
I'm using it mainly for SMB, Nextcloud (jail) and PiHole (Ubuntu VM)
I want to switch the 4x 3.5" 2TB disks from my old server to the new server.
Requirements are similar or less power consumption than N40L, more cpu power, and a pricetag that doesn't break the bank.
I like the Microserver 4x hot swap disk-feature, so I'm thinking of a similar setup.
I was thinking of this :
- Motherboard + atom processor : SuperMicro A2sdi-4c-hln4f (https://www.supermicro.com/en/products/motherboard/A2SDi-4C-HLN4F)
- Casing : Fractal Design Node 804 (https://www.fractal-design.com/products/cases/node/node-804/black/)
- Memory (non ECC) : 2400MHz DDR4 Non-ECC CL17 DIMM 2Rx8 (KVR24N17D8/16) (https://www.kingston.com/dataSheets/KVR24N17D8_16.pdf)
- Power supply : Silverstone SFX Series ST45SF (https://www.silverstonetek.com/product.php?pid=253&area=en)
- Boot drive : recover my 80 GB Intel Sata SSD
- Data drives : recover my 4x 2TB Western Digital Red 3.5" Hard disks
As I see it, this build will be a lot more powerful and will consume less power.
Don't know if it is the best bang-for buck.
Suggestions are welcome!
Thomas.
Thomas.
