Curious about this... :)
bcrowder
Just installed FreeNAS-8.2.0-BETA4-x64 (r11722) and seen this result in Physical memory utilization. First block on the graph was BETA3 doing nothing, second block on the graph was after the upgrade and walked away, third block on the graph was moving a couple 5gb files.
Thanks,
Bill
survive
Behold the Wumpus
Hi bcrowder,
I think that's exactly what you want to see.
The first graph is FN after it's been running a while and shows the growth in the memory caches that has taken place over time as you read & write to the filer.
The second is FN freshly booted with empty caches.
The third is with the caches starting to grow\fill up as you move data to\from the filer.
-Will
