I hope you guys will be gentle as I have barely any technical knowledge of FreeNAS. Our small business has a FreeNAS box built by a tech who no longer works for us. Based on what I've read here in the forums, I suspect our data is now corrupt and unrecoverable but would like the experts here to confirm and diagnose the cause before I finally give up.
The General Issue: Data Corruption. Almost all files are suspected corrupted, few files were spared.
Symptoms:
• Sample folder shown in Explorer on Windows 7:
Properties of a suspected corrupt file:
When opening one of the suspected corrupt files:
The error is similar for suspected corrupt pdf, excel, and word files.
• Same folder shown on Windows XP (even with "show hidden files and folders" enabled. Notice the suspected corrupt files aren't even showing):
System:
• FreeNAS-8.2.0-BETA4-x64 (r11722)
• AMD E-350 Processor (Dual Core)
• 2x2TB RaidZ1
• 8gb RAM, Non-ECC (Yes, I've read this maybe the culprit. I've ran memtest though and there were no errors)
Scrubs: run every 7 days. (recent scrub result below)
Virtualize: no
No other backups.
What I'm thinking the culprit is:
I hope I'm not taking the statements from this post (http://forums.freenas.org/threads/300-more-worth-it.15689/page-2) out of context, but I suspect one of the computers we're using may have a bad memory.
Questions:
1) Would just opening Windows Explorer by an offending client computer with bad memory cause widespread corruption? Because I know some of the files were not accessed for a long time.
2) Also, can you confirm that our data is no longer recoverable?
Thank you for your insights in advance.
Symptoms:
![FreeNAS-Win7.jpg](http://centuryhelimedia.com/images/FreeNAS-Win7.jpg)
![FreeNAS-File-Properties.jpg](http://centuryhelimedia.com/images/FreeNAS-File-Properties.jpg)
![FreeNAS-Open-Error.jpg](http://centuryhelimedia.com/images/FreeNAS-Open-Error.jpg)
![FreeNAS-WinXP.jpg](http://centuryhelimedia.com/images/FreeNAS-WinXP.jpg)
System:
• 2x2TB RaidZ1
![FreeNAS-Memtest.jpg](http://centuryhelimedia.com/images/FreeNAS-Memtest.jpg)
![FreeNAS-Scrub.jpg](http://centuryhelimedia.com/images/FreeNAS-Scrub.jpg)
Virtualize: no
No other backups.
Questions:
