CRITICAL: The boot volume state is DEGRADED
Myopia
I'm using FreeNAS for some years again, but now I ran into some issues. I got a mail from my FreeNAS, with the following message:
CRITICAL: The boot volume state is DEGRADED: One or more devices has experienced an error resulting in data corruption. Applications may be affected.
status says:
[root@freenas ~]# zpool status -v
  pool: archive
 state: ONLINE
status: Some supported features are not enabled on the pool. The pool can
		still be used, but some features are unavailable.
  scan: scrub repaired 0 in 2h47m with 0 errors on Sun Jun 17 02:48:00 2018
		NAME											STATE	 READ WRITE CKSUM
		archive										 ONLINE	   0	 0	 0
		  raidz1-0									  ONLINE	   0	 0	 0
			gptid/5bfba636-c382-11e5-a785-3ca82aa0da90  ONLINE	   0	 0	 0
			gptid/5ccd9c79-c382-11e5-a785-3ca82aa0da90  ONLINE	   0	 0	 0
			gptid/5da3c4a2-c382-11e5-a785-3ca82aa0da90  ONLINE	   0	 0	 0
errors: No known data errors
  pool: freenas-boot
 state: DEGRADED
action: Restore the file in question if possible.  Otherwise restore the
		entire pool from backup.
   see: http://illumos.org/msg/ZFS-8000-8A
  scan: scrub repaired 2K in 0h31m with 7 errors on Tue Jul  3 04:16:06 2018
		freenas-boot								  DEGRADED	 0	 0	 7
		  gptid/b7214029-ad5a-11e5-81d5-3ca82aa0da90  DEGRADED	 0	 0	27  too many errors
		freenas-boot/ROOT/11.0-U4@2017-03-12-14:27:13:/bin/dd
		freenas-boot/ROOT/11.0-U4@2017-03-12-14:27:13:/usr/local/lib/perl5/site_perl/mach/5.20/sys/proc.ph
		freenas-boot/ROOT/11.0-U4@2017-03-12-14:27:13:/usr/local/lib/perl5/site_perl/mach/5.20/sys/procctl.ph
		freenas-boot/ROOT/11.0-U4@2017-03-12-14:27:13:/usr/local/lib/perl5/site_perl/mach/5.20/sys/procdesc.ph
		freenas-boot/ROOT/11.0-U4@2017-03-12-14:27:13:/usr/local/lib/perl5/site_perl/mach/5.20/sys/queue.ph
		freenas-boot/ROOT/11.0-U4@2017-03-12-14:27:13:/usr/local/lib/perl5/site_perl/mach/5.20/sys/syscall.ph
		freenas-boot/ROOT/11.0-U4@2017-03-12-14:27:13:/usr/local/go/pkg/tool/freebsd_amd64/asm
What could be wrong? And what to do?
garm
Your boot pool is degraded. If you stated your hardware as per the forum rules you could have got a more detailed reply.
What you need to do is get a new boot device, install FreeNAS and reload your configuration. If you have not saved a configuration, do so before scrapping this boot device.
Myopia
System information:
HP MicroSvr Gen8 G1610T
Build
FreeNAS-11.0-U4 (54848d13b)
Platform Intel(R) Celeron(R) CPU G1610T @ 2.30GHz
Memory 12088MB
Myopia
So I just fresh install FreeNAS 11.1 and then restore the 11.0-U4 configuration file?
jro
That would be a good first step. You can backup your config by going to the web UI > System > General > "Save Config". After you reinstall, you'll restore the config on that same page.
Do you have your OS installed on a USB flash drive? If so, you might as well get another flash drive and reinstall on that instead. Those drives don't last indefinitely, but thankfully they're cheap and easy to replace.
Myopia
I've have succesfully installed a fresh version and updated the configuration file. Thumbs up for FreeNAS! It all went smoothly.
I got a few warnings:
  • WARNING: July 16, 2018, 9:13 p.m. - smartd_daemon is not running.
  • WARNING: July 16, 2018, 9:13 p.m. - New feature flags are available for volume archive. Refer to the "Upgrading a ZFS Pool" section of the User Guide for instructions.
Upgrading a ZFS pool, can this be done without any risk? And why would I do it?
kdragon75
Make sure you disable SMART for your USB boot drive as thins can prevent it from starting.
I try not to update things without reason. As this is not a security thing, I would just leave it unless you have a backup. Its a low risk thing but why take a chance. Feel free to read up on it and make your own call.
jro
The features added are the sha512 and skein hash functions. These are only useful if you have dedupe enabled on the pool in question. If you aren't using dedupe, you can skip this upgrade and just uncheck the warning in the status box.
When new features are released, you can read about them on FreeBSD's zpool-features man page: https://www.freebsd.org/cgi/man.cgi?query=zpool-features&sektion=7&n=1
There's some cool stuff in the works, so don't be afraid to upgrade your pool when you want to try out new stuff. It's generally a very safe operation unless you have backwards compatibility requirements on the pool (i.e., you want to replicate the pool to a system running an older version of FreeNAS/BSD, etc.).
Myopia
Thank you all for the great support! I'm very happy with my FreeNAS setup, which is running for 2,5 year. Sadly the SD card with the FreeNAS was degraged, but reinstallation and restoring configuration is very easy to do. Maybe in the future I will setup a new FreeNAS at a different location for data mirroring. :D
