[CRITICAL] Fail of boot drive
FantasyNoobs
Hi all,
I'm new to the freenas community, so i've recently create my own (spec in signature).
But since i've created it, i have always a mail with "Daily run output" saying this :
Checking status of zfs pools:
NAME           SIZE  ALLOC   FREE  CKPOINT  EXPANDSZ   FRAG    CAP  DEDUP  HEALTH  ALTROOT
Stockage      3.62T   588G  3.05T        -         -     0%    15%  1.00x  ONLINE  /mnt
freenas-boot   111G   759M   110G        -         -      -     0%  1.00x  ONLINE  -
  pool: freenas-boot
state: ONLINE
    corruption.  Applications may be affected.
action: Restore the file in question if possible.  Otherwise restore the
    entire pool from backup.
   see: http://illumos.org/msg/ZFS-8000-8A
  scan: none requested
    freenas-boot  ONLINE       0     0     2
      ada0p2    ONLINE       0     0     4
errors: 1 data errors, use '-v' for a list
-- End of daily output --
And also a mail with this (daily security run output) :
Fantasy-Nas.local kernel log messages:
> pid 60699 (pkg), uid 0: exited on signal 10 (core dumped)
-- End of security output --
I've checked other threads and people said that freenas does not send everyday messages. So i think my install have a problem.
Here the result of the zpool status -v :
 pool: Stockage
state: ONLINE
        Stockage                                        ONLINE       0     0     0
          raidz2-0                                      ONLINE       0     0     0
            gptid/194107c8-afa3-11e9-8335-309c23cd8a93  ONLINE       0     0     0
            gptid/1a684e25-afa3-11e9-8335-309c23cd8a93  ONLINE       0     0     0
            gptid/1b97505b-afa3-11e9-8335-309c23cd8a93  ONLINE       0     0     0
            gptid/1c9501c1-afa3-11e9-8335-309c23cd8a93  ONLINE       0     0     0
errors: No known data errors
  pool: freenas-boot
state: ONLINE
        freenas-boot  ONLINE       0     0     0
          ada0p2    ONLINE       0     0     0
        //usr/local/lib/python3.6/site-packages/aiohttp/__pycache__/web.cpython-36.opt-1.pyc
Thanks !
(Sorry for my bad english, i'm a french guy.)
FantasyNoobs
Update !
Now i had this message
FreeNAS @ Fantasy-Nas.local
New alerts:
* Boot Pool Status Is DEGRADED: One or more devices has experienced an error resulting in data corruption. Applications may be affected.
Gone alerts:
* Boot Pool Status Is ONLINE: One or more devices has experienced an error resulting in data corruption. Applications may be affected.
Current alerts:
scrub of pool 'freenas-boot' finished
Please help me, i don't know what is going wrong ...
Alecmascot
CraigD
Save your config to a location not on your server immediately, just in case
Then replace the failed drive
Have Fun
FantasyNoobs
Hello CraigD !
Thank you for your response.
You think my SSD boot drive is dead ? i bought it 7 days ago :(
Thanks.
The WD greens (and a bunch of other SSDs with some specific controllers and some types of 3D NAND) have an issue with TRIM which means either you need to buy a new boot drive (I went with Kingston) or disable TRIM (look for the article in the forum about that... I don't recommend it for performance reasons)
You can see in my sig that I had the same issue. I re-used those drives in a linux machine with no problems.
It should be perfectly safe for you to take a backup of your existing config and then restore it on a fresh install on the replacement boot drives. You won't lose anything.
FantasyNoobs
Thank you for your response !
You said Kingston, but SA400S37 120Go is great ?
THanks !
I am using SUV500/120G, but I don't think there's any reason the SA400S37/120G wouldn't be OK too. (or to use simpler english, it will be fine too)
SSD boot drives are already going to be much more reliable than USB and I have one system using USB boot for 3 years now.
FantasyNoobs
Ok thanks ! :) I will report back tomorrow when the i will install the new ssd !
