mstinaff
- Jan 21, 2014
I am running FreeNAS 9.2.0 with the CrashPlan plugin 3.5.3_1. I launched a remote head to this engine today and it seems to have triggered an upgrade of the engine from 3.5.3 to 3.6.3 (released today I believe)
Now the engine fails to start. From the engine_output.log
Any ideas? Other logs to check? If I re install the plugin is there any way to ensure that it doesn't try to upgrade itself again?
Many Thanks
[02.12.14 16:56:51.842 INFO main root ] END Loading Configuration jtux Loaded. Exiting!!! java.lang.RuntimeException: Unexpected IO Exception constructing selector engine - e=java.io.IOException: Function not implemented [02.12.14 16:56:53.267 INFO main root ] ***** STOPPING *****
Many Thanks
