SOLVED CPU widget in dashboard not updating temperature and usage in 12.0-U4
Ako
Yesterday I moved my system to HPE ProLiant MicroServer Gen10 Plus.
The CPU widget will show a constant average usage and there is no statistics on each thread. The reporting graphs looks fine.
Former hardware:
CPU: AMD Ryzen 7 3700X
MB: ASUS X470 Prime-Pro
MEM: Kingston Premier ECC Memory KSM32ES8/16ME (CL22, 3200MHz, 16G x4)
System SSD: Intel SSDSCIHF120A4H 120GB
Data HDD: Seagate EXOS X16 16TB * 4, Raid Z1
Current: (HPE ProLiant MicroServer Gen 10 Plus)
MEM: Kingston Premier ECC Memory KSM32ES8/16ME (CL22, 3200MHz, 16G x2), works at 2666 MHz.
System: Samsung FIT Plus USB 3.1 Flash Drive 128GB *2
Ako
The TrueNAS version on 2 machines are identical, 12.0-U4.
I saw some post about this issue on 12.0-U3, but I am still experiencing this problem after the update.
c77dk
There's already other threads about the same issue + a ticket in jira.
Ako
seems like the problem doesn't solve by updating from U4 to U4.1
works after a fresh install of U4.1
Redcoat
Did you clear your browser cache after updating?
