Could not determine size - now can't access drive
OmarOmar
Hello All,
I'm very new at all of this, please don't beat me up that much.
I did an upgrade for the 9.10 stable, after the upgrade I got the message in the subject. Restarting didn't work, shutting down didn't work, shutting down and physically disconnecting/reconnecting didn't work. Finally, I physically disconnected the drive, deleted the share and data-set (I did NOT select the option to delete data). So, I tried as the manual stated on importing a drive and volume. That was a couple days ago, at first I selected the import drive and it gave me the progress status bar for a whole 24 hours, is this normal for it take forever, the drive works and is healthy, I can see the drive. Since, I'm new I hadn't got around to creating a back up (I know).
1. How to import drive without erasing the data that is currently on it?
2. If I can't, how do I retrieve the data from the data from drive?
3. What information do all need to better assist me?
Thanks in advance, I admit I'm no expert but am willing to learn!!!
BigDave
FreeNAS Enthusiast
Hi there OmarOmar! Let's start out by giving you a link to the Forum Rules
Follow the guidelines all the way to the bottom of the page, don't skip
any steps cause we'll know, and you may be ignored.
Welcome to the forum!
OmarOmar
Lets try this again???
* FreeNAS-9.10-STABLE
* LGA1366 Socket
* Intel(R) Xeon(R) CPU E5504 @ 2.00GHz
* 16GB Crucial
* 2 - 2TB and 2 - 150GB
Request Method:
GET
Request URL: http://192.168.1.164/storage/import/
Software Version: FreeNAS-9.10-STABLE-201606270534 (dd17351)
Exception Type: UnboundLocalError
Exception Value:
local variable 'traceback' referenced before assignment
Exception Location: /usr/local/www/freenasUI/../freenasUI/storage/views.py in volimport, line 348
Server time: Thu, 7 Jul 2016 02:12:01 -0400
Traceback
Request information
GET
No GET data
POST
No POST data
FILES
No FILES data
COOKIES
Variable
Value
csrftoken 'V3uqWDQr0AuwvWUbJx0ejXSA0JBG5RzJ'
sessionid 'g6iixt7kih7zf9s4mwju027x86pqxee2'
fntreeSaveStateCookie 'root%2Croot%2F50%2F51%2F52%2Croot%2F1%2F5%2Croot%2F97%2F108%2Croot%2F1%2F6%2Croot%2F108%2Croot%2F108%2F121%2Croot%2F108%2F109%2Croot%2F112%2F125%2Croot%2F103%2Croot%2F116%2Croot%2F116%2F128%2Croot%2F116%2F127%2Croot%2F1%2Croot%2F112%2F124%2Croot%2F125%2Croot%2F133%2Croot%2F133%2F146%2Croot%2F121%2Croot%2F55%2F56%2F73%2Croot%2F108%2F120%2Croot%2F117%2F130%2Croot%2F55%2Croot%2F55%2F56%2Croot%2F112'
META
Variable
Value
HTTP_ACCEPT 'text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8'
wsgi.input <flup.server.fcgi_base.InputStream object at 0x815d53b10>
SERVER_PROTOCOL 'HTTP/1.1'
wsgi.multiprocess False
HTTPS ''
HTTP_HOST '192.168.1.164'
SERVER_PORT '80'
wsgi.run_once False
SERVER_SOFTWARE 'nginx/1.8.1'
SERVER_ADDR '192.168.1.164'
REMOTE_PORT '55403'
wsgi.version (1, 0)
HTTP_X_REQUESTED_WITH 'XMLHttpRequest'
wsgi.url_scheme 'http'
wsgi.errors <flup.server.fcgi_base.TeeOutputStream object at 0x815ca3450>
DOCUMENT_URI '/storage/import/'
REMOTE_ADDR '192.168.1.151'
CONTENT_TYPE 'application/x-www-form-urlencoded'
SCRIPT_NAME u''
CONTENT_LENGTH ''
GATEWAY_INTERFACE 'CGI/1.1'
HTTP_USER_AGENT 'Mozilla/5.0 (Windows NT 10.0; WOW64; rv:47.0) Gecko/20100101 Firefox/47.0'
DOCUMENT_ROOT '/usr/local/etc/nginx/html'
HTTP_ACCEPT_LANGUAGE 'en-US,en;q=0.5'
wsgi.multithread True
REDIRECT_STATUS '200'
HTTP_ACCEPT_ENCODING 'gzip, deflate'
CSRF_COOKIE u'V3uqWDQr0AuwvWUbJx0ejXSA0JBG5RzJ'
REQUEST_METHOD 'GET'
PATH_INFO u'/storage/import/'
HTTP_CONNECTION 'keep-alive'
HTTP_COOKIE 'csrftoken=V3uqWDQr0AuwvWUbJx0ejXSA0JBG5RzJ; sessionid=g6iixt7kih7zf9s4mwju027x86pqxee2; fntreeSaveStateCookie=root%2Croot%2F50%2F51%2F52%2Croot%2F1%2F5%2Croot%2F97%2F108%2Croot%2F1%2F6%2Croot%2F108%2Croot%2F108%2F121%2Croot%2F108%2F109%2Croot%2F112%2F125%2Croot%2F103%2Croot%2F116%2Croot%2F116%2F128%2Croot%2F116%2F127%2Croot%2F1%2Croot%2F112%2F124%2Croot%2F125%2Croot%2F133%2Croot%2F133%2F146%2Croot%2F121%2Croot%2F55%2F56%2F73%2Croot%2F108%2F120%2Croot%2F117%2F130%2Croot%2F55%2Croot%2F55%2F56%2Croot%2F112'
HTTP_REFERER 'http://192.168.1.164/'
HTTP_CONTENT_TYPE 'application/x-www-form-urlencoded'
REQUEST_URI '/storage/import/'
SERVER_NAME 'localhost'
QUERY_STRING ''
Now may I receive assistance please?
Mirfster
Finally, I physically disconnected the drive, deleted the share and data-set (I did do select the option to delete data).
Sounds like you already told it to delete the information... I personally don't think that it is possible since technically there is not any data.
I guess we really need to know how your Pool(s) were configured? If it was a Mirror, then maybe...
OmarOmar
If someone can help me out it would be appreciated very much!!!
As you see in the image below, "Church_Videos_3" is showing in the "zpool list" but won't mount?
2. If I can't, how do I retrieve the data from the drive (copy it from this drive to say "Church_Videos"?
Mirfster
Mirfster
How about for "Volume_1"; apologies I misread your earlier post and thought that the files/folders you were seeking were under "Church_Videos"; but now believe that they are under "Volume_1"...
So the command would be: ls /mnt/Volume_1
Check there and see if that is where your missing files/folders are from the "data from the data from drive"...
OmarOmar
Mirfster,
This is the drive that I'm trying/requesting help:
As you can see, it's in the zpool list, it still has the data on it, but it won't mount???
SweetAndLow
Sweet'NASty
Can you run 'zpool import'? This will show you the pools that are possible to import. You should also post your smart data for the drives that are part of that pool. This problem isn't related to the upgrade, it happened because something was broken already and you didn't notice until after the system rebooted.
gpsguy
Active Member
One question that you haven't answered, was how your pools were configured. Mirrored, some form of RAIDzX, or just a single drive (without any redundacy). For example, if the latter, was Church_Videos_3 on a single drive?
OmarOmar
gpsguy,
I apologize for missing this question, it was is on a single drive, I was waiting for an additional drive to arrive in the mail to setup mirror.
Stux
I'd need to double check, but I think if you "zpool export" the pool in the cli, then you can import it in the gui.
Stux
Stux
Try
% zpool export Church_Videos_3
If that hangs, it's a problem. I'd try waiting for it to finish.
Assuming it does finish, you now go into the GUI and import the pool.
OmarOmar
Try
This is what I get???
%: Too many arguments.
