I have starting to experience some problems with my FreeNAS 8.0.4 Release. When copying files to my client computer running Windows 7 via CIFS I pretty often get "File descriptor" errors or "File not available". Restart of the NAS-box did not help and restart of the client did not work either. I have one auxillirary parameter saying smb max protokol is smb2..
But when transferring via AFP to my Mac works. So it seems to have something to do with CIFS.
Has anyone experianced this?
I see the following message in the log:
Apr 27 07:19:35 eltoro-storage kernel: pid 2857 (smbd), uid 0: exited on signal 6
Apr 27 07:19:37 eltoro-storage kernel: pid 2858 (smbd), uid 0: exited on signal 6
Apr 27 07:20:16 eltoro-storage kernel: pid 2859 (smbd), uid 0: exited on signal 6
And this is from log.smbd
[2012/04/27 07:19:37.475276, 1] smbd/server.c:272(cleanup_timeout_fn)
Cleaning up brl and lock database after unclean shutdown
[2012/04/27 07:19:45.619391, 1] smbd/service.c:1081(make_connection_snum)
mini-sd (192.168.1.10) connect to service Blandat initially as user eltoro (uid=1001, gid=0) (pid 2859)
[2012/04/27 07:19:45.694845, 1] smbd/service.c:1081(make_connection_snum)
mini-sd (192.168.1.10) connect to service Media initially as user eltoro (uid=1001, gid=0) (pid 2859)
[2012/04/27 07:20:16.152769, 0] lib/fault.c:51(fault_report)
[2012/04/27 07:20:16.152817, 0] lib/fault.c:52(fault_report)
INTERNAL ERROR: Signal 11 in pid 2859 (3.6.3)
Please read the Trouble-Shooting section of the Samba3-HOWTO
[2012/04/27 07:20:16.152828, 0] lib/fault.c:54(fault_report)
From: http://www.samba.org/samba/docs/Samba3-HOWTO.pdf
[2012/04/27 07:20:16.152837, 0] lib/fault.c:55(fault_report)
[2012/04/27 07:20:16.152846, 0] lib/util.c:1117(smb_panic)
PANIC (pid 2859): internal error
[2012/04/27 07:20:16.152899, 0] lib/util.c:1221(log_stack_trace)
BACKTRACE: 0 stack frames:
[2012/04/27 07:20:16.152953, 0] lib/fault.c:416(dump_core)
dumping core in /var/log/samba/cores/smbd
[2012/04/27 07:20:16.154093, 1] smbd/server.c:300(remove_child_pid)
Scheduled cleanup of brl and lock database after unclean shutdown
[2012/04/27 07:20:16.989122, 1] smbd/service.c:1081(make_connection_snum)
mini-sd(192.168.1.10) connect to service Media initially as user eltoro (uid=1001, gid=0) (pid 2904)
[2012/04/27 07:20:36.154129, 1] smbd/server.c:272(cleanup_timeout_fn)
[2012/04/27 08:15:03.296345, 1] smbd/service.c:1081(make_connection_snum)
mini-sd (192.168.1.10) connect to service Blandat initially as user eltoro (uid=1001, gid=0) (pid 2904)
