Connectivity Issues: Unable to connect to Update TrueNas
damonizer
I have had issues with my onboard NIC and swapped for another USB NIC...but there must be some setting that i had forgotten to do.
So my plex jail is working well and can be accessed. However when ever try to update the Jail it give me connectivity errors.
I just tried to update my TrueNas and similarly had an issue and the error is :
Unable to connect to url https://update-master.ixsystems.com/TrueNAS/trains.txt: Automatic update check failed. Please check system network settings.
But my network settings looks fine...i had ensured that the nic is that is up is the new NIC,
Any help would be most appreciated.
Redcoat
Doesn't look like you have your default gateway set in Global Configuration.
192.168.97.1
