nj4ck
- Sep 24, 2016
Hi there,
I've been tasked with completely overhauling our NAS system at work, even though I have no idea what I'm doing when it comes to this kind if thing. It must be the fact that I occasionally build new PCs whenever needed that led my boss to believe I was the right guy for the job.
All whining aside, we're currently running a 12TB RAIDZ2 NAS with no backup and one drive already dead, so I really do need to get this done ASAP.
We use our NAS constantly, it is our main storage for all work performed on individual workstations (we're a 3D animation and visual effects studio). That means we are reading and writing large amounts of data pretty much all the time (projects can be several hundred GB that are created, moved, updated and removed constantly). There can be up to about 10 users accessing the NAS at the same time, usually the number will be more like 6 or 7.
What we need is a fast, secure and not entirely wallet-melting solution that should include a >12TB main NAS, an on-site mirror and an off-site backup that will likely be located at my boss's house. I was thinking possibly a RAID 10 main NAS with 6 4TB drives, a mirror using 6 3TB drives in RAID 6 and an off-site backup likely just consisting of two 6TB drives to keep the cost down. I'm thinking of using rsync (or maybe there's something better?) to keep the mirror up to date, but I haven't yet figured out a way to keep the off-site backup running.
Then there's the question of hardware. How much CPU do I need? How much RAM? Do I need a dedicated RAID controller? Our current NAS is running one of those ASRock ITX boards with a quad-core Atom and 16GB of RAM. Just looking at the graphs, it seems our CPU usage is fairly low, but RAM is pegged at 100% and we recently lost one of the 8GB DIMMs, leaving us with 8GB of RAM and noticably crippled read-write speeds.
I was looking into Synology earlier and noticed people saying things like "incredibly fast" about them, but even the high-end ones don't seem to have much RAM, so I'm not sure why our NAS seems to be needing so much of it.
Speaking of which, there seems to be a massive bottleneck somewhere in our current setup. Take a look at this:
Apart from one of the drives being dead, aren't those read/write speeds incredibly slow? Maybe I'm reading this wrong, but it seems like the drives are never exceeding 4.5MB/s read/write speeds? The only bottleneck I can spot is the RAM usage, but maybe there's a network issue too?
In conclusion, I have more questions than I can even remember right now, but the main ones are:
1. What kind of NAS setup would you recommend for our purposes?
2. How important is CPU/RAM and could it be causing the slow speeds we're currently experiencing?
3. How would you recommend setting up an off-site backup for a 12TB NAS?
If anyone could help me out, I'd really, really appreciate that. I'm under quite a bit of pressure to get this figured out before our current NAS craps out any more and causes data loss. Essentially, I've got very limited time to learn how to NAS and do it properly on the first try.
Any help would be greatly appreciated.
![4Cs04BQ.jpg](http://i.imgur.com/4Cs04BQ.jpg)
